Question about Sony DCR-HC26 Mini DV Digital Camcorder
DCR-H26 Sony Camcorder has grey lines running thru the screen on playback.
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Nov 04, 2010
  • 188 Answers
SOURCE: camcorder
if all the indicators i.e. battery condition, play mark, counter, etc are visible on the screen then it can be a simple problem of dirty video head. try using a head cleaning cassette or do the head cleaning manually, Open the cover by removing three screws on the right hand side next to the viewfinder. Slide it little towards front and pick it up. The video head will be visible.
Posted on Sep 15, 2006
  • 188 Answers
SOURCE: sony dcr-trv120 playback
the problem is with the video head. either it's dirty or broken. if cleaning tape is not solving the problem then i fear you have to get the head changed. an expensive repair.
Posted on Jan 18, 2008
welcomejee
  • 10594 Answers
SOURCE: Camcorder Sony CCD-TR705E
Nops buddy,
You need to replace video head assy. Will be available at nearrest Sony repair shop.
Posted on Jun 03, 2008
zohail
  • 1223 Answers
SOURCE: Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
Posted on May 25, 2009
  • 497 Answers
SOURCE: camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System.
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 23, 2009
I have a sony camcorder DCR-HC48. My viewfinder is not working and I would like to know if there is any way to fix it? The screen is just grey when the camera is on.
Does the viewer screen work when playing back a tape? If yes, then you have may have a sensor problem with the camera. If the playback tape does not appear on the viewer screen, then it sounds like a faulty connection between the camera and the viewer screen. In either case, you will probably need to discuss repairs with Sony Tech Support / Video Camera Repair. The number as listed on their website: Priority Service Line (for U.S. only): 239-768-7547
After you wade through the recorded-message-menu-maze and get to Camcorder Repair Department, you will receive quality assistance for the issue. (I recently had a similar problem with one of my Sony cameras and had to call them to schedule repairs.)
May 15, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
I HAVE FIVE GREY LINES WHEN I RECORD AND PLAYBACK YOU CAN SEE THE PICTURE BETWEEN GREY LINES
Sounds like the video heads require cleaning.
It may be best to take the camera to a Service Centre.
Apr 15, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Sony handycam dcr-pc106e pal
Video head is dirty / clogged, please use good quality video head cleaning cassette.
Sep 06, 2008 | E.Digital DCR-PC106E DIGITAL CAMCORDER
LCD screen had two grey lines
I recently had the same problem. All I did was buy a Head Cleaner, followed the instructions, and now my camera works fine. It only cost me A$12 and I bought it from a shop specialising in digital video cameras. I hope this helps.
Sep 02, 2008 | Sony Handycam DCR-TRV460E Digital...
Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
Feb 09, 2008 | Sony Handycam DCR-PC110 Mini DV Digital...
Grey lines during playback on touch screen
I think im having the same issue. Is this what it looks like?
Jan 08, 2008 | Sony DCR-PC55 Mini DV Digital Camcorder
4-5 Grey Lines appearing in the Playback Mode when playing tape
I have the same problem happening and can't find a straight answer. Some posts are leading me to believe that it may be dirty heads, and that the camera needs cleaning.
Oct 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC26 Mini DV Digital Camcorder Logo
202 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
