Question about ASUS P4P800-MX Motherboard
P4P800-mx motherboard. Powers up fine, no beep codes no video. Does send signal to monitor that it is there.
    Sergeant:
  • 281 Answers
Pulls out the memory, video card and also check all wires to ensure that they are in the correct places and seated correctly. Also if this is an system thats been around awhile clean the dust out. I just had the same problem because of dust.
Posted on Nov 03, 2010
What does the different warning signals of asus p5vd2-mx mean?
The POST code error for this is -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Jul 16, 2012 | ASUS P5VD2-MX Motherboard
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
Twice beep sound is coming. Booting is not happening for my p4p800 mx/s board
Hello !
If you check out ASUS support, you will find this troubleshooter for the motherboard not booting :
1. Please clear CMOS.
2. Please take out your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Please take the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Please keep the necessary components(CPU, one memory) onboard for a test.
Finally, we would recommend you to replace a BIOS battery to have a test.
Also, by looking over beep codes I have found for AMI BIOS these problems for the 2 short beeps :
1. Memory parity error (Description : A memory parity error has occured in the first 64 KB of RAM. The RAM IC is probably bad).
2. POST fail (Description : One of the hardware tests have failed).
If you have done those and it still doesn't boot, let me know I'll try to find other solutions.
All the best !
Aug 03, 2011 | ASUS P4P800-MX Motherboard
Asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Sep 05, 2009 | ASUS P4P800-VM Motherboard
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
I want to use another video card
You can install anoth video card without turning th onboard video off, you will see the option to use the new video card in the windows display settings, if you do not hook a monitor up to the onboard video it will not use it either.
Mar 10, 2009 | ASUS P4P800-MX Motherboard
Asus p4p800-x no screen no beep
Could be that your ram is either Bad or the wrong type. I just had a similar problem. I changed the ram and up it came.
Aug 04, 2008 | ASUS P4P800-X Pentium Motherboard
Well it looks like oxidized RAM problem. Remove the RAM module from its slot, rub it with an eraser and put it back into its slot. This should probably get it working.
Jul 12, 2008 | ASUS P4P800-MX Motherboard
Asus P4P 800 motherboard no signal on monitor
Make sure that the right video source is selected in BIOS.
Nov 30, 2007 | ASUS P4P800-MX Motherboard
ASUS P4P800-MX Motherboard Logo
151 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
