The pitch on my Roland Juno-G keeps shifting and the sounds become detuned for no reason.
  • 979 Answers
I'm sorry, but I must disagree with the last post from VOTIT concerning the IC amp section. Believe the problem is going to be further back in the processor section, and that you'll find an incorrect voltage present, or one that is not stable...accordianman
Posted on Jun 14, 2008
  • 2,071 Answers
The main problem with your Roland Juno-G shifting sounds and detune is in the amplifier section. The power I.C(integrated circuit) there have a problem or its defected try to reheat the solder of that I.C(integrated circuit) If nothing happens change that I.C
How to program arrpeggiator in Roland Juno D
The information is in the manual. You can download a copy here-
JUNO Owner Manual JUNO Manuals Support Roland
Feb 27, 2015 | Roland Juno-D
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
HI, I have a Roland Juno GI, (5 months old), have not programmed anything into it or changed any settings. However, when I started it today it was flat by 50 cents. I was sure of this by checking a D or G...
It sounds like it is transposed. Look for the transpose function in your user manual. It shifts the keys by half notes either up or down. I would be surprised that factory reset would not clear the transpose setting. First, realize that these keyboards are controlled by a crystal oscillator and they just don't drift enough to shift even one cent worth.
IF the unit is NOT transposed, then the other problem is LIKELY with the pitch bend wheel. Try the action of the wheel and make sure it responds by moving up and down about 50 cents. If it doesn't go both ways, it is possible the mechanism has slipped or been damaged.
Jul 19, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Where do I install the expansion card on Roland Juno stage
You install the expansion card to the bottom side of the Juno by removing screws. For detailed step by step instructions, I suggest that you refer to page 174 from the manual that you can download from: JUNO-G Owners Manual (JUNO-G_OM.pdf)
Apr 17, 2011 | Roland Juno Stage EXpandable Synth
How can I fix a pitchbend that doesn't work at all on a ROLAND JUNO 2?
Some have found that doing a "Factory Reset" has cured an inoperative pitch bend control.
If that doesn't work, inspect the control for mechanical damage and replace broken parts as needed.
Mar 21, 2011 | Music
Roland juno d not pikkingup volume but very low sound comimg out on speakers.
Check if headphone output is normal... sometimes the headphone jack switch fails and doesn't send to speakers when headphones are unplugged.
Oct 20, 2010 | Roland Juno-D
I wish to know how to open a Roland JUNO-D synth to access the little rubber strips with the key contacts; I have the typical key-not-sounding problem.
Usually there are a number of screws from the bottom to remove. SOmetimes they hide some under a label or rubber feet. The top should remove and pone must be careful of the cables from teh top to the base of the unit.
Keep track of where screws go as often they have different length and using the wrong length when re-assmbling caan cause trouble.
Aug 07, 2010 | Roland JUNO-D Synthesizer
We have the roland juno d and we can't figure out the split for two sounds
you could try using 2 midi channels for two sounds.
Feb 11, 2010 | Roland Juno-D
Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
Feb 06, 2010 | Roland Juno-D
My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
May 31, 2009 | Roland Juno-D
196 people viewed this question
 Grubhead
Grubhead
