Question about Frigidaire FRS26KW3AW Side by Side Refrigerator
Hotpoint Future Frost Free Fridge/freezer
For the past few days the fridge part which is t the top is hot because the "food defrost" light is constantly on.
howdo i combat this - each time i press the light off it comes back on after a minute or so.
the dr
  • 447 Answers
SOURCE: Fridge not cooling compressor works intermitently
Is the brand name of the compressor Tecumseh?? How old is this fridge??
Posted on Jan 10, 2008
  • 1314 Answers
SOURCE: odours from fridge
frigidare makes a product called fridge- aid you can get it at lowes or any appliances parts store its made of activated coconut charcole it might solve you promblem
Posted on Jan 15, 2008
  • 1314 Answers
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Posted on Mar 30, 2008
  • 161 Answers
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Posted on Dec 22, 2008
  • 478 Answers
SOURCE: Things are freezing in my Fridge & Water Dispenser isn't working
Wrap all food together in blankets to insulate. But first check for a kink at the bottom of the freezer door where the water line comes up trough the door ,disconnect and press for water. If not check at filter if all fails; replace water valve.
Posted on Mar 25, 2009
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
I have frost free hotpoint future,the fridge seems to be working but the freezer isnt at the minute, the food is not freezing and the fan does not seem to be working! it has no suction on doors either, my...
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 15, 2010 | Refrigerators
My frost free fridge freezer has stopped working(beko) the fan inside the freezer is consyantly on the food in the freezer has defrosted and the element at the back is usually hot and now its cold
Please checck to see if your thermostat lines are in order or if some of the connecting wires are damaged bby frost. First of all switch off the fridge and allow all frost to clear. then check for the fan circuit, the auto defrost timer circuit. Now after few hours switch on the fridge. Check to see if the compressor is running the back side is getting warm and the freezer is cooling. If not check if the compressor is pumping well or being short of gas-- get help -. If not the timer could be the culprit as after the cooling takes place the fridge does not defrost. Check this out and the fault is confirmed if your fridge works fine now. Hope you try. Good day
Aug 11, 2010 | Refrigerators
Got a hotpoint ffa97, freezer was still cold and no alarm had gone off to say that that there had been a power cut yet the fridge temp had risen enough to curdle milk??\r\ntemp gauge was still showing...
Milk can sometimes curdle in a working fridge. But it does sound like your defrost system may be malfunctioning. Can you empty your freezer and inspect the defrost system behind the air circulator fan?
I know that defrost elements sometimes go bad and the controllers can pop too. You should check your operators manual and see how to put the fridge into manual defrost. *(it usually involves turning the fridge light on and off by hand. See if the freezer drains during manual defrost. If you have lots of food that dries out in a frost free unit the moisture contains a lot of contaminants that can plug the defrost drain. Which leads to a blocked air passage between the freezer and fridge sides.
You might want to get a small backup fridge for a while to run this down.
Or just use up the food in your fridge before running the tests.
Good luck and be careful.
Jun 28, 2010 | Hotpoint Refrigerators
Hotpoint frost free ff200e flashing lights and beeper freezer food defrosting
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Jul 05, 2009 | Hotpoint Refrigerators
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
Freezer compartment
You need to defrost the whole fridge and at the back in the freezer compartment you will c a small drainage hole.. look for it.. The get a piece of say hanger wire and clean this pour some hot water from a kettle down it and then start your fridge up again. that should sort your problem out ... if not then its either a sensor or a board fault...
Dec 03, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Frigidaire FRS26KW3AW Side by Side Refrigerator Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
