Question about Porter Cable Tools & Hardware - Others
I have a Porter Cable 503 belt sander that heats up to the point that I can't touch it and have to stop using it to let it cool. I have been using this model for years, have relied on it exclusively, and have more than one. But this one I purchased brand new a couple of years ago when Porter Cable stopped production of the 503 model. I have sent it to my local Porter Cable (Dewalt, Black & Decker, whatever) service center for repair at least twice while it was under warranty: once to repair the heating up and also to repair blown seals, and a second time for the same problems immediately after getting it back. Now the seals are okay but the overheating persists. I appreciate the company's honoring my warranty; however, it seems that they are unable to address the overheating problem.
    Genius:
  • 1,015 Answers
I have a black and decker BR300 that I've had the same problem with.I don't know if yours is caused by the same things but what I found was that the vacumn system on mine was not sealed up good enough and too much dust was getting around motor cooling fins. Unfortunatly on mine by the time I figured this out it had frayed the drive belt which caused some small strands to wrap around drive gears and mostly trashed the motor. Hope this is of some help to you. Thanks
Posted on Nov 03, 2010
How do I remove the rotating disk on a porter cable polisher model 7336
You have to use a wrench behind the disk for a stop and then unscrew from the housing Porter Cable
Feb 23, 2013 | Porter Cable Porter-Cable Variable Speed...
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
My Porter Cable 4" Belt
I would check both rollers for debris on them, also check the plate on the bottom for unusual wear, be careful for sharp edges and make sure the front of the plate is not worn excessively. Then I would turn the front roller without the belt on it to make sure not out of round and moving smoothly. Lastly if you are using directional belts make sure installed properly with the arrow pointing to the front of the sander. Let me know if you need more help before voting and I will see what I can do.
Feb 13, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 7800 Drywall Sander- Head overheating/motor laboring
the drive shaft is probably going bad. If all the greese is gone then it will cause it to heat up. you can find parts and diagrams to fix it at www.deltaportercable.com. search for modle number 7800 under the parts section.
Mar 08, 2009 | Black & Decker Black Decker/ Porter Cable...
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
290 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
Jay Finke
Jay Finke
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
