Question about Indesit W 123 Front Load Washer
Water leaking out through powder drawer
When my machine gets to the rinse/ spin bit of the cycle, water gushes out through the poweder drawer all over the floor! could it be a valve problem and how do i fix it please ( its 5 yrs old)
many thanks
  • 1,036 Answers
It could be the machine is over-filling.
There is a presure switch inside which regulates the water height.
If the water level is over half-way - it needs adjusting or replacing.
Posted on Jun 22, 2008
  • 66 Answers
Please take your drawer out and give a good clean also look inside when drawer is out and clean there as well good luck regards jason
Posted on Jun 15, 2008
How do I get fabric softener to flow into washing machine
jrez's answer is for toploaders... you said you have a drawer, so it's a front loader.
The softener is usually taken up by a syphon. This can be removed from the drawer assembly for cleaning, when they clog they can't syphon.
While the machine is taking water for the last rinse, some of the incoming water is sent via the softener compartment. As softener is thick, without a syphon the softener would just sit in the bottom of the compartment and the fresh water would just skim off the top.
SO: Check the drawer after the final rinse.. if the softener compartment is full to the brim, the syphon is blocked. OR .. if there's just the same amount of softener as when you started the cycle, you have a filling problem instead.
Filling problem can be for two reasons: early machines had one water valve, and a flap which squirted water into the various compartments, operated by a linkage from the timer - this linkage can break, the spring can fall off, all mechanical. Later machines use a separate water valve, and this can fail shut.
Feb 15, 2015 | Washing Machines
The city turned off the water to fix a main line and then turned the water back on. The first time I started the washer after this happened, I heard a loud pop noise and the water began gushing into the...
After repairing the pipeline it's inevitable that some debris/stones/cement etc. would find it's way into your machine. Even though there is (or should be) a filter in the water input hose, I'd guess that the water pressure was so high that some debris damaged the electrically operated solenoid valve which controls the water input flow. A mechanical problem then, with possibly some associated electrical fault. If you can get the machine out, I suggest unscrewing the inlet hose and having a look at the valve - they're usually easy to get to. But please DISCONNECT THE ELECTRICAL SUPPLY AND WATER first.
May 25, 2014 | Asko W6661 Front Load Washer
Water leaking from detergent drawer Hotpoint WMD 962
what is your model number is then we can get started then okay
Feb 04, 2013 | Hotpoint Washing Machines
Frequent leaks through soap drawer during rinse cycle
Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
click on : Dispenser
Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
On spin the water comes up the dispenser tray and overflows
Pull the dispenser drawer all the way out, there will be a flat part which you push down to slide the drawer out, Then you can get to the inside to give it a clean, next you can remove the top by undoing the 2 screws at the back and sliding it off, you will see the hoses that run to the dispenser and you can clean them with a bottle brush.
Mar 10, 2012 | Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
The fabric softner isn't draining during cycle but the bleach and detergent do just fine. I took out drawer and cleaned the dispenser but still won't empty. Help!
When cleaning the softener chamber, make sure you remove and clean the syphon tube thoroughly. This is the only chamber designed to handle liquid. Otherwise, check that you have sufficient water pressure and that the cold valve opens fully. If you dont hear a decent gush of water during the rinse cycle, it's either pressure or the valve.
Dec 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Indesit W 123 Front Load Washer Logo
150 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
