During booting i hear a long beep of my laptop keyboard for about two minutes then to stops
  • 186 Answers
I would check the RAM first. If you have two sticks installed , pull one out and try to start. If you get the same result, switch the sticks of RAM around and try again. Maybe just one stick is bad. You really need to try to install a known good stick of RAM.
Posted on Nov 03, 2010
My laptop starts but won't display. I hear loud beeps during this process, what could be the problem?
What are the beeps as they are the clue to the problem. Count the beeps.
May 12, 2016 | HP 650 Notebook PC
My acer aspitre 5733Z makes a loud beeping noise on a black screen and won't stop until i shut it off? I tried disconnecting the battery but its not that?
First, try removing the battery and unplugging the laptop. While still unplugged and with the battery still out, press the power button for 30 seconds or so (this will release the static electricity inside). Then put the battery back in and start it up again. This is called a hard reset, and it will fix a number of problems.
Apr 25, 2012 | Acer Aspire 5733z-4851
How can I stop the volume from playing about every 20 to 30 seconds
im not sure what volume sounds you are hearing every 20/30 sec if they are not beeps
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Jun 21, 2011 | Computers & Internet
I am having Acer Aspire 5738 which i am using every day since 11/2 year. Yesterday When I switched on the laptop it was beeping during the startup for a 1 min or so say 10 to 15 beeps and then it stopped...
Does it now work ok??
Does it boot up without the beeps?
You could try reseating the memory. Take it out and put it back in, most beeps at startup are memory.
It may also have been a key stuck on the keyboard.
Sep 04, 2010 | Acer Aspire Notebook
Hearing continuous beep sound at startup that disappears on Esc
I started having the smae problem yesterday with my Acer 1410 bought end of 2009. It started after I had stoped some suspicious process to work on start up (using msconfig). During the night I scanned the computer for virus but found nothing. Tonight I will enable those process to work on start up again and see what happens.
I will post the information tomorrow.
Aug 02, 2010 | Acer Aspire One PC Notebook
Accidentaly spalshed some water on my laptop keyboard.
You may have to replace your keyboard at best. As this can be a difficult process depending on the laptop, I recommend a trained professional.
The loud beeping noise is called a beep code. One beep in most causes is a DRAM failure, which could mean that the problem goes deeper than a few messed up keys.
However once electronics become water damaged they are beyond repair. The minute amount of minerals in the water is enough to short out the tiny circuits in the keyboard and cause malfunction.
Jan 22, 2010 | Sony VAIO VGN-N325E Notebook
WHEN I SWITCH IT ON IT KEEPS BEEPING LIKE A BUTTON IS PRESSED DOWN
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Dec 15, 2009 | Compaq Armada E500 Notebook
Beep noise during booting and no keyboard response
Sounds like the key is stuck. You will have to remove the keypad to check the switch underneath.
Mar 14, 2009 | Dell Latitude D800 Notebook
Computers & Internet Logo
19 people viewed this question
Alun Cox
k24674
