Question about Kenmore Washing Machines
How do I replace the agitator on my Kenmore 80 series
  • Kenmore Master
  • 1,344 Answers
First thing is to take the cap off the middle (where you add the soap). Once that is done, look down inside and you'll aee another lid thing( not in all models). Remove that and then you will see a 7/16 bolt directly in the middle. Get a socket wrench with an extension and remove it. Pull the agitator out, and insert the new one. Put the bolt back in and everything else and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Nov 03, 2010
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
80-series w/ broken top agitator
There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore series 80 washer: does not twist in the middle
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced.
Remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Part number is 80040
Let me know if you need more help.
Apr 01, 2009 | Kenmore Washing Machines
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Washing Machines Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
