Question about Nokia N73 Cellular Phone
N73 memory full
My phone memory is full even there is a little data on it and even no other application installed. I'm willing to reformat it or restore to factory setting. Please help. Thanks
  • Anonymous Dec 26, 2008
    i tried to do the same way over over again but still after a few days the problem comes back..
  • kate0313 Jan 06, 2009
    DO NOT execute if you do not want to lose data from you phone memory specially, you contacts data. I did this and I lost all of them :(
  • 24 Answers
U may press, *#7370# then it will show the lock code that is 12345 then ur phone will restart and the problem will definetly solve.
Posted on Jun 13, 2008
I had the same problem few times b4. I noticed that it happens when i change the mobile theme and replace it with a downloaded one from untrusted websites. My suggestions are:
a. if you recently changed ur mobile theme then replace it with one of the themes preinstalled on ur mobile.
b. go to application manager and check the installed applications on ur mobile. there might be a new one that's consuming all the memory and most probably the supplier will be unkown (may be a virus or sthg). So check the size and the supplier of this application if it's too big with an unkown supplier, remove it right away.
c. last option remove the memory card from ur phone, restart it and then reinsert it again.
Hope this helped. Worked for me!
Posted on Dec 17, 2009
Hi, My N73 shows Memory full & ask to delete some data, except the phone book i have deleted all the other data, but still the problem persist, i am not able to send or receive mgs's nor view the...
Its mean phone memory is full, you can make some space by deleting some installed application. Delete also all cache/history in your browser. If the problem persist, reset your phone to factory setting after put off your memory card. After resetting the phone, your phone memory will be empty again and you can reinstall your previous application. Avoid to install application in phone memory (always install in memory card).
Hope this help.
Feb 25, 2011 | Nokia N73 Cellular Phone
N73 Cellular Phone: my nokia n73 memory low delete some data sir what ...
This problem Arises When your Phone memory(C:\ Drive) Is almost Full .normally C: Drive Has 44.4MB Space. But When it goes below 500KB,it shows
"memory low delete some data"
So delete unwanted files from phone memory using any Good File managers .One i suggest is Using "Xplore" An application for n73
Which can be downloaded Here
Or else use Phones inbuilt file manager to delete unwanted files from phone memory.
Hope this will solve your problem
(Alternate download Path Click HERE)
May 16, 2010 | Nokia N73 Cellular Phone
I have n73 with the problem memory full delete some data but i was already delete all contacts,messages and other data after that my phone memory status shows used memory 44mb and problem will never solve...
you can try to another memory for that since you already tried to reformat the cellphone...or also you can try to reformat the memory card by going to memory card icon then choose option to format memory card
Apr 05, 2010 | Nokia N73 Cellular Phone
How to reformat my n73?
nothing wrong. plz remove your memory card in then insert it againg after turning the phone off man!
Mar 23, 2010 | Nokia N73 Cellular Phone
I have not installed much applications on my nokia
Goto message setting and select the memory card.
Now all the messages stored in the memory card.
It defenitly works...
Rate it....
Mar 02, 2010 | Nokia N73 Cellular Phone
Cant open applications' say memory full
This is an issue which arises when the Phone's memory is full. This means that the Phone's memory is containing applications which is occupying the Whole phone memory. To access a application, some free memory is required. I think the phone has a memory status lower than the Memory requirement used in opening an application. Try Reformatting the Phone memory. But first try to note down or backup all the Phone's data. This will help you to retrieve the data after reformatting.
Thank you, Have a nice day.
Sep 28, 2009 | Nokia N97 Cell Phone
Always showing memory full, delete some data, i deleted almost all the data. if i will open the messege, showing memory full.
press GREEN,* and 3 simultaneously while turning it on..do not let go until hands appear..then reformat memory card.. NOTE:this procedure erase data in your phone so be sure to back up your data..your phone is infected with virus so formatting is necessary..
Jun 13, 2009 | Nokia N73 Cellular Phone
My fone shows the msg that memory full delete some data...
Solution:
1.Move your images & Videos from Phone Memory to Memory Card..
2.Install Applications in Memory Card Only..
3.if this issue still persists use this reset code
*#7370#
Feb 12, 2009 | Nokia N73 Cellular Phone
Memory full?
try this. this helps me..
turn off your n73 phone. turn it on. while your mobile is booting, hold
3 + * and the green call key at your left soft key until it ask your location.. select your location and BAM! your phone is new again and 44mb is back.
note: before doing this back up your files to your memory card and remove it removed it from your phone. =) This is SAFE!
Nov 19, 2007 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
586 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
