Question about Epson Stylus Photo R300 InkJet Printer
Cd print problems
The printer is printing on a4 paper but printer canot print on cd printing fails every time tried.
  • PCUser Jun 18, 2008
    Same problem. CD tray feeds through to the back and then keeps on being ejected. Error message is "CD/DVD tray is not set correctly".
  • Anonymous Aug 27, 2008
    i have the same problem the caddy wont feed into the printer and the error keeps saying paper jam when there is no paper in the printer
  • Epson Master
  • 691 Answers
Hey James,
A common issue with the R300 once it begins to age is that dirt builds up on the exit rollers. The exit rollers are responsible for pulling out the paper when in normal mode which is not much of an issue if the rollers are dirty. After all they helped by the rollers at the paper intake which also push the paper.
When it comes to feeding the CD caddy, the feed rollers have to have a certain amount of grip to maintain the timing tolerances required. if the rollers struggle to feed the leading edge of the caddy in good time - an error occurs.
Solution number ONE:
Clean the exit rollers with a little soapy water on a DAMP lint free cloth. Rotate the rollers (which are hard to get at if your hands are bigger than those of an infant Rhesus Monkey!!) as you clean them to ensure a good all over cleaning.
Solution number TWO:
The white marks printed on the caddy are required to be seen by the "magic eye" on the underside of the print head. If the white marks are dirty the eye can't see them, looses the location and progress of the feed and panics. The result is the error message. Clean the white marks using soapy water and don't rub too hard or you'll scrub the marks off !!
It is also possible that the "magic eye" under the head is covered with ink. This is much harder to solve and if you feel that this may the cause, get back to me and I will sort you some more inclusive info.
Solution number THREE:
The leading edge of the older versions of the caddy had a thin transparent strip attached to it. If this strip gets a decent crease or "nick" in it, it will not feed through the rollers. Check the caddy you have for the clear strip. The newer version does not have the strip but instead had a shallow bevel to the leading edge.
If your strip is badly creased or bent, straighten it as best you can. You may find simply giving the caddy a nudge as it starts to feed solves the issue. If so, look on ebay or other site for a new caddy and you should be sorted.
Hope this helps. PLEASE, let us know which if any of the above info helps you sort your issue. If your issue is not sorted by the above info, please give us chance to offer further assistance before you rate this post.
Many Thanks
Posted on Jun 14, 2008
    Genius:
  • 2,985 Answers
The most common problem here is 'Back of machine clearance'
The disc carrier has to pass right through the machine and back again.
Describe the nature of the 'Fail'
Put A4 in upper tray error
Change the printer properties to use paper from the automatic feeder tray. And, unless you are in Europe, you probably don't want to specify A4 paper. Try "letter" or some other size.
The manual is at this URL. See page 49 http://www.manualslib.com/manual/113847/Oki-B4545-Mfp.html
Apr 25, 2016 | OKI Office Equipment & Supplies
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
A4 paper giving error
When you print, under "Paper" be sure that the paper source is set to "Auto Select" in the options.
Apr 08, 2009 | HP LaserJet 1005w Printer
The epson printer driver dealing with cd printing is not installed
is there an ok button on that error message? if so just click on OK button and click on a button says manual.
It will let you check on the settings on the printer. paper size should be A4.
on print settings it should let you select on cd/dvd
Note: this only works if you have installed the epson easy print from the epson.com website of your printer model
Feb 07, 2009 | Epson Stylus Photo R200 InkJet Printer
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Mp 160
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
550
Feb 11, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Epson Stylus Photo R300 InkJet Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
