My monitor Model is:SyncMaster793s The screen is showing in shadow of every font and folders please help us
How do I change the font and icon size on the monitor. I have two monitors and font and icons are different sizes.
Change the Resolution of the 2 monitors to match the setting you prefer. (Right-Click on Desktop, choose "Screen resolution" It should show both monitors.Set resolution on the "Wrong" screen to match the settings on the "Correct" screen.
Oct 11, 2015 | HP W2007 LCD Monitor
HP w19b "shadow"
OSD has no shadow shows monitor itself is OK and problem is in cable. Barrow a cable from friend and confirm the result.
Regards,
Sep 02, 2008 | HP Computers & Internet
Pop ups and its slow
Well it can be many reasons why it's slow, but I have a few things you could do that may help.
First make sure you have security for your system. Microsoft Security Essentials is free. It can guard your system from viruses, spyware, and other malicious software. Below is some of my notes from college on speeding up your computer. I hope this helps.
Indexing service is a little program that uses a large amount of RAM. The program indexes and list files that are on your computer so when you do a search for things on your computer it can find it faster by scanning the index list. You don't need this service so to disable it.
Go to start
settings
control panel
add/remove programs
add/remove windows components
uncheck the index services
click next
Optimize display settings
visual items can waste system resources
to optimize:
start
settings
control settings
control panel
system
advanced tab
in the performance tab click settings
leave only the following ticked
show shadows under menus
show shadows under mouse pointer
show translucent selection rectangle
used drop shadows for icons labels on the desktop
use visual styles on windows and buttons
Speedup folder browser
when you open mycomputer the slight delay is because win xp searches for network files and printers every time you open windows explorer
mycomputer
tools folder options
view tab
uncheck the automatically search for network folders and printers check box
click apply
click ok
reboot comp
Remove the Desktop Picture
Your desktop background consumes a fair amount of memory and can slow the loading time of your system. Removing it will improve performance.
Right click on Desktop and select Properties
Select the Desktop tab
In the Background window select None
Click Ok
Remove Fonts for Speed
Fonts, especially TrueType fonts, use quite a bit of system resources. For optimal performance, trim your fonts down to just those that you need to use on a daily basis and fonts that applications may require.
Open Control Panel
Open Fonts folder
Move fonts you don't need to a temporary directory (e.g. C:FONTBKUP?) just in case you need or want to bring a few of them back. The more fonts you uninstall, the more system resources you will gain.
Free up disk space
The Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
Use Disk Cleanup to:
Remove temporary Internet files.
Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
Empty the Recycle Bin.
Remove Windows temporary files such as error reports.
Remove optional Windows components that you don't use.
Remove installed programs that you no longer use.
Remove unused restore points and shadow copies from System Restore.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
Speed up access to data
Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.
Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.
When to run Disk Defragmenter
In addition to running Disk Defragmenter at regular intervals-monthly is optimal-there are other times you should run it too, such as when:
You add a large number of files.
Your free disk space totals 15 percent or less.
You install new programs or a new version of Windows.
Feb 11, 2014 | HP Computers & Internet
How do I enlarge my font?
Depends on the service you use. attaching two screen caps that should help you.
Gmail
Hotmail
Aug 21, 2013 | Computers & Internet
How to increase font size on my macbook permanently.
When you are on the finder Click View, scroll down to 'show view options' and from there you can change the font size looks on the desktop. You can even make the folders bigger.
To make the font bigger for folders open the desired folder you want and go to the view menu and like above goto the "show view options' option and when the window pops up you can adjust the font size.
I also suggest dropping your screen resolution to a lower number. That can be found by clicking the apple, going to system preferences and click displays under the hardware header. From there move the resolution down to 1280 x 800 or 1024 x 768. But for screen legibility and such I would not drop the resolution any farther than 1024 x 768.
Hope that helps!
Jan 27, 2011 | Apple MacBook Mac Notebook
Display is not clear in the monitor(colour is not orginal)
Right click empty space on desktop screen
see PROPERTIES in dialogue box ?
open SETTING TAB adjust fonts adjust setting for resolution also adjust choices in font shadow You can check box for clear edges of icons
Jun 11, 2010 | Intel Motherboard
Just set up monitor after we moved. The fonts on microsoft features are now small. Attempt to change font size (on control panel) are not successful. example of "features" = task bar words very small,...
anywhere on the desktop(not over an icon or folder) right click on the mouse and go to properties. A window called display properties will come up. On th tabs at the top click on settings.
There will be a slider bar called screen resolution, move the slider down and the windows icons and folders and fonts will get larger adjust this and keep clicking apply until it was the same size previously
Aug 22, 2009 | Acer Computers & Internet
Computers & Internet Logo
20 people viewed this question
Alun Cox
k24674
