Question about BenQ MP610 Multimedia Projector
Benq MP620c not recognized by RS232 PC (Win XP) COM1 connection. COM1 setup 115200 b/s,8,N,1. Projector in StandBy mode The PC continually search for BenQ, even at different speed. My I have some assistance ? Thank you Ugo Dalla Longa udallal@tin.it
    Problem Solver:
  • 7 Answers
CONTACT BENQ COMPANY AND ASK FOR PROJECTOR CONTROL TOOLS FOR RS-232
BY USING HYPER TERMINAL YOU MIGHT BE NOT ABLE TO CONTROL PROJECTOR
Posted on Apr 12, 2009
  • 682 Answers
Please try to switch your pc on first and then your projector-use fn(key) in conjunction with f4 or f5 or f6 or f7.
Posted on Jun 17, 2008
Power but no display
you have to change the video out put on the laptop and it is differant for each setup if you are running win 7 you will find connect to projector in the control panel
Apr 28, 2013 | BenQ Office Equipment & Supplies
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
Lantronix UDS1100 what are the pin connection to emulate com1 on a PC
Please see the link here below for the complete manual.
http://www.lantronix.com/pdf/UDS1100_UG.pdf
If you go to page 70 you will see the complete pin layout for RS232, if you need to connect it to a PC with a 9 pin RS232 port you can see the equivalent on page 72.
Please let me know if you need more details.
Mar 15, 2011 | Lantronix UDS1100 (UD110000201)
BENQ MP620C: We changed the bulb when old one was in 4000hours, but cannot reset the lamp timer? How to do this, because the projector turns itself off very quickly (we have maybe 30sec. time to...
I also had this problem but was able to get to the menu before it turned itself off..... Instructions in the manuel on how to reset the timer.
15. Resetting the lamp counter
Do not reset if the lamp is not replaced as this could cause
damage.
i. Press and hold the Exit 5 button on the
projector for 5 seconds to display the total used
lamp time.
ii. Press Auto on the projector or on the remote
control to reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
Jan 01, 2011 | BenQ MP620 Multimedia Projector
Changed my projector lamp yesterday, it work for about 4hours and went on standby. its now on a stanby mode and all effort to switch it on has not been successful. Please help me
Hi!
Is your projector connected to a source? ( Computer, DVD, or any device) make sure the connection is tight/properly plug in so that the projector will recognize the device attach to it and override the standby mode.
Hope this helps, thanks for contacting Fixya. Please keep us posted of issue. Cheers!
Dec 09, 2010 | Panasonic PT-AX200 LCD Projector
Connecting to a projector, presentation mode is
Try right clicking on your desktop, go to properties, then settings, you should see display 1 and display 2, right click on 2 and select attach.
If its not there press FN+F8 a few times, also look for the presentation software that came with your laptop and see if it has the feature to turn it on.
Oct 17, 2009 | Dell Computers & Internet
Acer 4736 compatibility with eb-s6 projector in usb display mode.
Check the Microsoft knowledge base for a "workaround" for this issue.
Try doing a search for "device not recognized" there should be several steps to correct this issue. However this may be due to compatibility with your projector and the usb port drivers. Contact the manufacturer or go to his website for driver and usb information on your Projector ability to connect to your Acer. Good luck!
Aug 13, 2009 | Computers & Internet
BenQ 8700 projector solution
Hi Rick
The upgrade is the same one used for the BenQ PE8720
Whoever told you this obviously did'nt know this.
You'll be needing Flashloader and the RS232 cable that came with the Projector.
It is absolutely cheeky of them to suggest that you should just use the Component input for all your applications on this Projector.
Make sure they understand that this was a top of the range Projector when you bought it and that it is not a good enough answer.
Apr 02, 2008 | BenQ PE8700 Multimedia Projector
Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Mar 12, 2008 | Zebra Z4Mplus Label Printer
Projector problems
Hi David IB
I've had teh same experience with a BenQ MP720 ( just the XGA version of your Projector )
I queried this with BenQ Engineer in Dubai and he said that it sometimes works exactly like a short on the machine.
If I could give you a tip , If it happens again don't put back the metal cover of the Mainboard it solves the problem 100%
Nov 19, 2007 | Office Equipment & Supplies
BenQ MP610 Multimedia Projector Logo
585 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
