Question about Wacom Intuos2 4 x 5 USB (INTOUS)
Same here, gum works ok, pen does not work Maybe Windows 7 is the culprit?
C pen driver 600mx
Will C-Pen 600C work with Windows 7 and Windows Vista? software for C-Pen 600C (C-Win 3.24) is not compatible with these operating systems.
however you can install http://download.anoto.com/ctech/C-Win_3_24.exe and use software with "Microsoft XP Mode".
Apr 22, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
Windows 7,Linux and other OS install from USB Pen drive, Flash Drive
To Install Windows 7 via USB Flash Drive (Pen Drive)
You need:
USB Flash Drive (Pen Drive) minimum 4 gb for windows 7
Windows 7 ISO image file.
UNetbootin software download from here UNetbootin
Download the Unetbootin software, and open the file and click "RUN".
below window will pop
You can aslo install other OS's like linux etc etc. for Windows 7, click "Diskimage" radio button, locate or browse the ISO file of your OS by clicking "..." button.
select Drive: (in my PC usb drive is "I:" and press OK.
Next window looks like below picture
Wait till Installation Compleate.
after compleation. Click "reboot" to install to the same PC, or remove the Flash drive(Pen drive) and plug it to another PC or Laptop USB
and boot that System by USB Flash drive.
To do this Select the USB boot option from the BIOS. Or to boot from USB go through your Motherboard User Manual.
This method works on most of Machines with USB booting option.
I personally installed 100's of PC's via this method
thank you. Keep smiling. aaarwind
for other OS setup's via USB drive refer to below Website:
UNetbootin - Homepage
on Jan 20, 2011 | Computers & Internet
Tip
Make Pen Drive To Reset Windows 7 Password
Most of us have a PC at home and one at work. We use our work PC most of the times and home PC comparatively less. Did it ever happen to you that you forgot your Windows 7 Password ? Maybe you go for a month long vacations or business trip and when you are back, you may forget some of your passwords to the home Windows 7 PC.
We tend to have lots of passwords at work, online and at various computers. So to save yourself from a locked out situation, we recommend that you create a password reset disk.
In this article, I will share with you a very simple method to create a Windows 7 Password Reset Pen Drive. So next time you are locked out of Windows 7 at the login screen, you can plug in this USB pen drive in your computer and reset the Windows Password.
To create a Windows 7 Password reset pen drive, I advice to have a small capacity pen drive which is cheap and you should keep it at a safe place, but not so safe that you forget where you kept it when you need it sometime in future.
Follow these simple steps:
Step 1. Insert a pen drive (backup any data if present on the pen drive and delete everything). Then go to Windows 7 Start Menu and type “create password reset disk” in the start menu search and launch the program “Create a password reset disk ” which will be highlighted in the search results.
Step 2. Just follow the simple Password reset Wizard as seen below, by selecting the pen drive from a list of drives it will show you. Note: If you have not inserted a Pen Drive before launching the utility, it will not work and will give an error. If the pen drive is in place, you will see Wizard something like the images below. It will also ask for your current password to create a password reset pen drive.
Step 3. Now you simple need to keep this drive at a safe place. You can use this in case you forget your Windows 7 Password sometime in future, just click forgotten password on the login screen and choose the option to Reset Password after inserting this pen drive into any of the working USB ports of your computer.
NOTE: Windows will honor only the most recent Password reset disk that you have created, so in case you happen to create more than one disk, only the one which is latest will work, all other old password reset disk will not be able to reset the Windows 7 Password.
If you have not created a reset disk and have forgotten your password, you can still reset the password using some utilities like Windows Password Recovery Tool. But these processes may cost you little money if you need to buy a software to do that. So to avoid any inconvenience later, we recommend that you create a password reset disk.
Related source: http://www.lostwindowspassword.com
on Apr 20, 2010 | Computers & Internet
Genius G-Pen 560 Tablet Driver won't Install on Windows 7
If you have Windows 7 Professional or Ultimate you can install XP mode and Windows Virtual PC on top of Windows 7 and run XP mode.Install the drivers on XP mode and you should be able to use your tablet.
Virtual PC and XP mode are available free of charge on the Microsoft web site. The site requires authentification to verify that your copy of Windows is genuine.
Apr 03, 2012 | Genius G-Pen 560, USB 4.5 x 6 tablet with...
Pen drive is detected other windows7 but didn't show my computer
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))julyallan01_30.jpg
Oct 11, 2010 | Microsoft Windows 98 for PC
Tip
How to install windows 7 from pen drive
Its very difficult to install windows 7 if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows 7 DVD
Step 1: Download HP USB storage format tool from here and install on your computer.
Step 2: Once you finish installation, double click on HP USB storage format tool and format your pen drive in NTFS
For this, select NTFS from File system option and Check quick format option and click on start.
While doing the format the data stored on your Pendrive will be lost. You keep a back if needed. Press YES on the warning message
Once the format finished you will get a message with the details and Click
on OK
Now insert Windows 7 DVD in to DVD Drive and go to command prompt.
For that go to start -> RUN and type CMD and press enter or OK
You will see the command prompt with black back ground
Now you need to change the directory to your DVD drive where you put the windows vista DVD.
For that type G: and press enter (here I am using G because in my system DVD drive letter is G. So you need to check your DVD drive letter and type accordingly)
So the directory will change to G:>
Now type cd boot and press enter
Now the interface will be like G:boot>
Then type bootsect.exe /nt60 h: (where h is the drive letter of your pen drive)
Now you will get a successful message like below
Now you can close the command prompt and copy all the contents from the windows 7 DVD to the pen drive
It will start copying now
Once it’s finished, you need to restart your pc and access the bios of your system and make first boot device as USB pen drive.
That’s it, now you can see installation starts from the USB pen drive.
on Mar 02, 2010 | Computers & Internet
Wacom Stylus not working on my DTZ1200. It shows that the pen is being red by the tablet but doesnt show the target from the pen point or be able to select from any selection in photoshop. Its and old...
you may have installed the driver for windows xp or a later version then windows 7, you will have to make sure you install the correct driver for you OS
Aug 16, 2010 | Wacom Stylus Pen for Graphire4
I have a genius wizard pen 4 x 3, about 5 years old. Can it work with a new computer that has windows 7, 64 bit?
hi, i have the same tablet wizard pen 4x3, windows 7 64bit install the tablet but doesnt work. if you could find a solution please contact me, i'll do the same for you, got this page in my favs for repair stuff..
esmilodonte arroba gmail dot com
peace and be nice
Apr 18, 2010 | Genius WizardPen 4x3 (K941C001) Graphic...
It won't show up on my windows media play what do I do?
OK see if the following works:
1.plug your pen drive 32gb in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pen-drive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 21, 2010 | Emerson BAR901 MP3 Player
No one knows how to turn on pen pressure for photoshop 7
If you haven't tried this yet:
First go to "Windows" on the task-bar of Photoshop.
Go down and select Brushes.
A window should pop up with several different setting for your brush. Check the Shape Dynamics if it isn't checked.
And then the pen pressure should work I believe. Hope I helped.
Apr 11, 2009 | Genius G-Pen F610 (31100050100)
Computers & Internet Logo
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
