Question about Coleman Mach 15 Air Conditioner
Coleman rv air
Was cleaning it and pulled a little red wire lose on top were the relays are dont no were to put the wire back at. thank you
  • 3 Answers
Try looking for a place on the relay that doesn't have a wire on it. Replace the red wire their.
Posted on Aug 14, 2008
Coleman mach rv central air conditioner maintenance
maintaining rv a/c is just a matter of changing filters, cleaning coils and drain lines. visual inspection of wireing for heat damage.
Jun 18, 2014 | Coleman Heating & Cooling
Have atwood furnace and coleman mach thermostat and it would not shut off. I unplugged power to rv and had to hit battery disconnect so that it would stop.waited few minutes...turned on...heat would not...
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Apr 23, 2010 | Coleman Mach III Air Conditioner
Easy Start Capacitor
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Feb 21, 2010 | Dometic Rooftop RV Air Conditioner
DOES MY COLEMAN ROOTOP HAVE FILTER ON THE OUTSIDE (ROOFTOP)
You dont have a filter on top unit but you need to have your fan impeller and condensing coil clean regularly about once a year and more when your on dusty area.
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Where are the drainage hoses located on a 2005 coleman rv ac
many times the pan of the evaporator in intergral with the drainage. You need to pull the cover and see which way the pan is pitched you should be able to trace it that way.
Jul 12, 2009 | Coleman Mach 15 Air Conditioner
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
Coleman Mach 15 Air Conditioner Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
