Question about HP Computers & Internet
It won't turn on,
I needed to quickly turn my laptop off, so I took out the battery, and put it back in. It won't turn on, with or without the AC adaptor. I've also tried blowing where the AC adaptor goes, and the battery. The battery does have a slightly shorter life span.
  • 611 Answers
Change the other battery work's if the work then you battery work goes
Posted on Jun 13, 2008
Compaq Presario x1000 with no battery won't start off AC
Battery is needed to complete circuit. Too bad you didn't have the old one.
http://www.ebay.com/itm/Battery-For-HP-Pavilion-ZT3300-ZT3200-ZT3100-ZT3000-Compaq-Presario-X1000-X1200-/150853086051?pt=Laptop_Batteries&hash=item231f8b6b63
Not advertising, it is just an example.
Still doesn't work after Battery installed, post back in a Comment.
Suggest do not be so quick to toss it away.
Regards,
joecoolvette
Dec 19, 2012 | Compaq Presario X1000 Notebook
I have a HP laptop that won't power up. I put in a new battery, and bought a new AC adapter. Now lights nothing. It was running than just quick and I haven't been able to get it to come back o
Hi There,
If you've got a multimeter - test your AC adapter to see if it is outputting the correct voltage for your laptop. If it is, Then you've got an HP boat anchor. Unfortunately HP laptops are known for their overheating issues, and if this is the case, a lawsuit filed against said manufacturer means you may be able to be compensated for your loss.
Jul 18, 2012 | Computers & Internet
Toshiba A200 1vo. works on battery but freezes when ac adaptor is inserted then has to be turned off manually-no keys function at all except on/off button.Won't start upon ac adaptor either although...
You say you bought a new adapter--was is a Toshiba adapter? Was it a "generic" one?
You have to be careful, because some adapters have different polarity and could damage the computer.
If you are sure the adapter is OK and is putting out the correct voltage (~18 v.) then disconnect the battery and try running the computer without the battery just using the adapter.
I don't think this is a BIOS problem. The operating system should not affect the function of the adapter.Most likely you have a motherboard problem if all else is working.
May 31, 2011 | Computers & Internet
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Battery was running out on my Acer mini book, hibernated and turned of, tried to turn it on nothing happened., used ac adaptor....still nothing
take battery out, unplug ac adapter. Wait one minute. leave battery out. Plug in ac adapter and turn on laptop. Once it turns back on. Shut down laptop and put battery back in. Now you should be able to turn laptop on with or without battery.
Nov 08, 2009 | Acer Aspire One AOA150-1635 Notebook
Hp zd8000 wont turn on...
hi thanks for using fixya!!
Try first to remove the battery and connect the AC adapter to your laptop, you will use the power supply directly from the AC adapter without the battery. Turn on your laptop, then if its working normally as it should be,
Then try now to install back the battery then connect the AC adapter, turn it on. If still does not work, perhaps you have a problem with the battery.
If you need further assistance, let me know.
May 24, 2009 | HP Pavilion zd8000 Notebook
Laptop is nmot working
hi,
welcome to fixya,
as u said that ur laptop is not working and it is not booting,i mean is it a dark screen or do u see the lights on the computer,can u clarify me pls...u can try and safe mode and if it doesnt load in safe mode then what u can do is that disconnect the ac adaptor and take out the battery and then without ac adaptor and the battery press and hold down the power button for one minute and then release the power button and then connect the power cord and put the battery back in and then turn on the computer,and if still it doesnt turn on then try and connect with the different wall outlet and if still doesnt turn on then try with the different ac adaptor and still if it doesnt work then replace the motherboard and the ac adaptor.
Feb 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
Can't get laptop to turn on. Battery pack lights show full charge, power cord is plugged in. No indicator lights illuminating at all, wondering if it is my motherboard. Compaq Presario 2200 laptop.
very first thing u have do is if u have any other laptop try and connect the aac adaptor with that laptop and also try the battery if it is working with the other laptop that means the motherboard of the computer has gone bad u need to replace it and what also u can try is disconnect the ac adaptor and take out the battery from the laptop and the without ac adaptor and the battery press and hold down the power button for one minute and then connect the ac adaptor and put the battery back in and then try and turn on the computer and also what u can do is shut down the computer first and then just hit the power butoon once only to turn it on and then keep tapping f8 key on the keyboard and it will take u to windows advance options and select safe mode with networking and then try if it turns on to the windows screen or not......and if it doesnt turn ono then definately replace the motherboard...good luck....
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
