Question about Philips 42PF9630A 42 in. Plasma Television
42PF7320A/37 My plasma tv wont come on, clicks in the back and led flashes. In the front of the tv the LED flashes 5 times, do you know what five flashes mean?
  • bjh_0330 Oct 01, 2008
    is there a diagram to show where this chip belongs?
    Problem Solver:
  • 5 Answers
Replace X-tal (Viper) on SSB (item 1H00, order code: 2422 543 01397).
REMARKS:
- Error 5: Viper does not boot.
- Only a "reboot" is visible in the Debug menu.
- Error will appear after heating up of the xtal.
HISTORY:
23-03-'06: Chassis added. Text updated.
Posted on Jun 14, 2008
  • YASSER ADEL Jun 16, 2008
    i send text to you to FixYa.com - if you wont service manual we can send it -but i wont mail to send manual
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Mar 08, 2009 | Philips Televison & Video
Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Dec 06, 2008 | Televison & Video
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 inch plasma 42pf7320a/37
My TV this with this . What can be ?
philips-42-inch-plasma-42pf7320a-37-nhe5gy2xupfnvv1disgbrgaq-1-2.jpg Help me please
Nov 13, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
42PF7320A/37
Regards
Has already received a question for the Philips plasma television from yrush member had asked about the location of damaged Crystal View I should send him service Manuel If he wants
With greetings ------------------------------------------------------------------------------------------
Symptom
TV turns "off" by itself, the LED blinks 5 times. Cure
Replace X-tal (Viper) on SSB (item 1H00, order code: 2422 543 01397). REMARKS:
- Error will appear after heating up of the xtal. HISTORY:
23-03-'06: Chassis added. Text updated. yassur
Jun 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
299 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
