Hey I was typing on my Westinghouse Laptop then all of a sudden the keyboard just stopped working. Can you help me?
    Master:
  • 474 Answers
How about just right clicking on " MY COMPUTER " and going to device manager and checking to see if the keyboard has an error status. I.E. it has a red X on it.
If so, try downloading new drivers for your laptop from the manufacturer website.
If it apears to be working normally according to Device Manager. Then you may have a bad connection. O the bottom there may be screws with a tiny PIC of a keyboard, undo these or it may come off from the top. You will have top determine this yourself. be carefull theres sensitive plastic pieces.
Once the keyboard is able to come off, carefully lift it and check the connection ribbon that attaches it to the Mobo.
Try this after trying the stuf the other guys said and if there advice didnt work. It may be a SIMPLE problem.
Plug in an External Keyboard. If it works fine then your keyboard may have just gone bad.
that or the connection on the motherboard.
Its hard to tell so check all the simple things first and work your way out. and dont spend more than a third of the money the laptop costs, trying to fix it. It will be obsolete in 2 years anyway, just save for a new one with a good warranty.
Posted on Jun 15, 2008
Try to solve your problem you can use your lap top temporary buy a new keyboard attached to your lap top see to it there is usb port. Or else they keyboard is dirthy try to clean and touch all character on the keyboard maybe there is not functioning. thanks
    Guru:
  • 859 Answers
Would you like to keep this simple?
Many times Windows will post an Alert box on screen and it may load behind your current application you're in. Until this alert box is acknowledge or dismissed nothing else will happen on your keyboard.
My philosophy on these things is this: the more complex and issue appears the simpler the answer will be.
So, I'm certain this is a simple problem with an easy answer.
Regards,
Worldvet
Posted on Jun 14, 2008
    Novelist:
  • 150 Answers
Did you try re-booting the machine ?
If that did not solve the problem, you may have a bad keyboard,
but let's check a few other things first.
1) Make sure that you have not somehow locked the machine,
with a key combination --> check your manual if your
laptop has such capability.
2) Make sure the Numlock key is not activated, this
causes the alpha keys to put out number on most
laptops.
3) Also check the scroll lock key.
4) If you are in Windows, open up notepad using the mouse
from the Start --> Accesories --> Notepad menu, and
check every single key on the keyboard for signs of
activity.
Sometimes only certain rows or columns will not work,
indicating a bad connection on the (internal) ribbon
connector.
If you get zip, re-boot windows using the power key.
press and hold it until the computer powers off,
then turn it back on.
5) When the machine is re-booting, try to hit any (all) of the
function keys, esc or del to see if you can enter the
BIOS.
Also try the CAP's lock and NumLock keys and watch
the corresponding LED's
If the keyboard responds during boot, you have a windows
problem. If not, the hardware is bad.
6) Try connecting an external key-board into a USB port,
to see if you can regain control of the computer.
7) If windows is the problem, and you can get in with an
external keyboard, then you may be able to fix it. If not
then you would have to re-install windows, either form
the factory CD's or from the backup recovery partition
(see the user manual or manufacturer tech support)
8) If the hardware is at fault, which is most likely, unfortunately,
and if the rest of the laptop works, than the most likely culprit
is the internal keyboard cable.
Unlike a desktop PC, which connects the keyboard to the
computer using a thin serial cable (or wireless), the laptop
directly scans the built-in keyboard by treating it as a matrix
containing rows and columns of keys. Each row and column
has a dedicated wire connected to it.
The computer outputs an active rotating bit pattern on the
rows of this array (or columns) and senses the input pattern
on the columns (or rows). The row and column combination
as a function of time uniquely identifies each key.
The keyboard is connected to the main circuit board using
a paper thin ribbon cable, which looks like an ultra-thin,
semi-transparent flexible printed circuit board. This cable
is extremely fragile so you have to be careful. The ends
of this ribbon slide into special edge connectors, which
are extremely tight on most PC's that I have taken apart.
Pulling them out is hard, putting them back in is harder.
(I wrote another article on FixYa regarding this topic)
9) The biggest challenge is to find out how to lift the laptop
cover, without damaging anything.
a) Use another computer to search the WEB for your
model's disassembly manual. Download and print it
Shut of the laptop, unplug it, and remove the battery
(Removing the battery is very important to prevent
damage)
b) Try to turn the laptop back on, to drain any residual
power from internal capacitors and wait at least
30 minutes.
c) Disassemble the laptop to get access to the top cover.
You may have to remove the CD player, the internal
hard drive and other modules to get access to screws
beneath them. You should NOT have to remove the
LCD hinge assembly. There may be hidden clips and
access points in the top of the PC or where the top
and bottom are sandwiched together.
Be very gentle. You can also slide a small exacto-knife
into the cracks in the chassis assembly to see where
the anchor points are hidden, but do NOT force anything.
This is why a disassembly manual is so important,
every laptop is different, and the a'oleis that make them
spend millions trying to find ways to keep guys like you
and me out.
10) Once you do get the bas'd open, look for the ribbon
cable and gently wiggle it. This may fix the problem.
You can also plug all the modules back in, as well as the
battery, and operate the unit with the top cover removed,
while you poke around.
11) If the keyboard is bad you can often get a cheap
replacement on eBay.
12) To replace the keyboard, you need to very carefully
pull out the printed ribbon cable. The best way to do
this is with a long hooked pair of electronic needle-nose
pliers or tweezers, but wrap some soft tape around them
to make sure that you don't scratch or cut the
conductors, which would be game over.
Plastic surgical clamps also work, but down over-
tighten them
In the short term you can also try to run the laptop with
and external USB keyboard, which will allow you to
narrow down the problem between hardware vs software,
as a mentioned above.
Good luck, hope this works for you.
Martin
Laptop to tv via hdmi cable suddenly stopped working
Maybe your tv's input is not set to hdmi. Also make sure you reboot the laptop. You might have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the display. The correct key that toggles the display will have CRT/LCD on it or it might have the icon of a display.
May 07, 2012 | Computers & Internet
I have an idea pad s10E and the keyboard has suddenly stopped working, even though the mouse works... Could anyone help with telling me what's wrong? Thanks
The connectors inside the laptop are fragile and a good jolt may have unshipped the connector. The mousepad and keyboard have separate connectors. But it usually an easy job to reconnect these types of keyboards. Good luck.
Jan 26, 2012 | Lenovo Computers & Internet
Im using my mom Dell latitude D600 PC Laptop and It was working good then all of sudden S key wont Stop typing itself Till we press "r or T" it making it hard when it pops up out the blue. it...
It seems that your laptop keyboard is not working any more. you need to buy new keyboard for ur laptop or if you want to use usb keyboard then remove this keyboard's cable, connect your usb keyboard it will work.
Aug 21, 2011 | Dell Latitude D600 Notebook
Using my computer to access the internet it suddenly stopped typing 'l' and then started typing 'l' without stopping. I have disconnected from the internet and now it will not type 'l' in a word document....
This is going to sound odd, but i you 'slam' the I key down, does it work occasionally? Somtimes this is all it takes.. otherwise you will probably need to have the keyboard cleaned or replaced.. however, in the meantime, you can always connect an external USB keyboard to your laptop and use it instead of the laptop keyboard.
Mar 13, 2011 | Acer Computers & Internet
The Gateway keyboard suddenly stops typing. We
This might be a driver issue or firmware problem. I would recommend that you visit the gateway site and start with the driver download program. This will ensure that your software for your keyboard and drivers are updated to the latest. Please visit http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=CL2cl4HorZwCFShRagodzCOQjw&hit=1
To download the gateway driver search program or choose from the list that is provided. IE: windows version etc.
Hope this helps
Aug 18, 2009 | Gateway 2520915 Keyboard
Keyboard on hp dv7-1130us stopped working
This sounds alot like a virus i once had!
try a system restore to the point before these problems occured. if that doesnt work run a full virus scan. If that doesnt fix the problem you may have to wipe the hard drive completly.
Apr 26, 2009 | HP Pavilion dv7-1130us laptop
How to deactivate internal keyboard - Dell Inspiron 9400
if you go to the control panel, to hardware, in the keyboard section you should be able to uninstall the internal keyboards driver which will stop it working.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
My keyboard doesn't work
Hello tdclaude,
Without being able to physically look at the laptop, it is very hard to determine the cause. Here is a good article concerning a dead laptop keyboard:
http://tech.yahoo.com/gd/dealing-with-a-dead-laptop-keyboard/153166
- Vincent
Nov 22, 2008 | Compaq Presario 2100T Notebook
Computers & Internet Logo
287 people viewed this question
David Payne
David Payne
