Question about Dishwashers
The Bosch plastic push button (AP2804452) has broken on my SHU9950 dishwasher. The switch itself is still good. I have removed the broken pieces of the bad button from the unit and am now depressing the switch without the button. When I get the new push button, what is the proper way to remove the control panel cover to put the new button in place? Thanks!
natengel
  • 19 Answers
SOURCE: access controls
screw driver hex#15
Posted on Oct 31, 2007
SOURCE: Broken door handle Indesit dishwasher DG 6100
broken door handle solution
Posted on Mar 07, 2008
Krazytech
  • 725 Answers
SOURCE: The bosch dishwasher will not start
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
SOURCE: Bosch Dishwasher on/off
It could be the switch. If the black plastic On/Off button comes all the back up into cutout in the top of the door, you must remove the front of the door (10 little screws; two shims will probably fall out; good luck figuring out how they go back) and then the plastic top (4 little screws) that contains the On/Off and the wash mode buttons. Now you've exposed the real on/off switch, which has a reddish/brown stem (at least on my unit). Test the switch; if the DW doesn't stay on when you depress it, you need a new switch. If it stays on, then goes off when you depress it again, the switch is likely good and maybe you have a problem with the black plastic cover button.
Posted on Jan 13, 2009
  • 45 Answers
SOURCE: Door lach/handle plastic pins have broken off and
handle was redesigned with a metal rod through the attachment points to prevent breaking. the handle and latch comes as a complete assembly (you don't have to put it together).
Posted on Jan 10, 2010
Do you have any schematics to put the front plate back on
They go in the lower section of the door panel to prevent it from bowing and popping. If you look at how the insulation is cut you will see, I think they face sideways. You may also have an imprint on the sheetmetal of the door about 4" up from bottom if I recall
Sep 06, 2009 | Bosch SHU9950 Dishwasher
In Sink Erator Classic Supreme with sensor problem
I would assume that in the last year you've either fixed the washer or have gotten a new one. If your curious, this is probably the solution. There's a plastic piece that pushed a button when you open the latch and resets the washer. The piece is probably broken. If you remove the screws on the top of the door, you can reach in and manually push the button. You can also tape some metal into the end of the plastic piece so it will still push the button. A flattened bottle cap will work.
Oct 19, 2008 | Dishwashers
Shu9950 white plastic shims
Hello Folks.
Just spent the last 45 mins on my back under the SHU 9950's door, with a kettle of (cold!) water sitting just above the soap dispenser - the door will spring back up with the front removed. Basically there are three "components" to the shim: the flat side, the short comb side and the longer comb side. The way that worked for me was, with the door elevated about 20 degrees, I slotted in the top five flanges, having already placed the shim in the middle of the insulation cutout area on the door-front, flat side against the door, long comb closest to the door-front's side. You should push the short comb flush up against the insulation, so that the shim will be clear of the two door pieces when you fit them together. The shims seem to serve 2 purposes: preventing the door from torqueing as well as allowing the door to open perpendicular to the unit. Good luck!
Sep 19, 2008 | Bosch SHU9950 Dishwasher
Aug 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Is there a way to turn off the cycle completion signal. I have a Bosch SHY66C02UC/14
OK, I think I have figured this out. Let me first give this important piece of information. The control panel for my dishwasher was replaced recently. That's why I now have to deal with this issue. I have a Bosch SHY66C model. As I stated in a previous post, the user manual I found on the web has identical structions for changing the amount of rinse aid dispensed and for changing the volume on the cycle completion beeper (or for disabling it). Following the instructions fixed the former.
Here is what I did
1) With dishwasher off, I pressed and held the "Delay Start Hours" button
2) I pressed the on/off button. The beeper begin to sound.
3) I released both buttons (not sure this step is necessary)
4) I repeatedly pressed the "Delay Start Hours" button until the signal turned off
(LED display showed 0)
5) I pressed the on/off button (not sure this still is necessary)
That seems to have fixed the problem. So, I don't know if the user manual is wrong or my control panel was replaced with one from a different model (such as the SHU9950 where I found these instructions).
Jul 24, 2008 | Bosch SHU9915UC Dishwasher
Bosch SHV 6800 dishwasher, 2HR error
Bosch dishwasher all cycles start at 2H and get hungup on 1 min.
Jul 02, 2008 | Bosch SHU9950 Dishwasher
May 30, 2008 | Bosch SHU9950 Dishwasher
Bosch Dishwasher stuck in "Scrub Cycle"
The Control module on our SHU43 blew this morning and when I took it apart to get the module out, I discovered why two of the Cycle selections no longer worked..... the little plastic lever that pushed the switch behind the fascia button - had broken off. You may have the same issue. It's not a cheap fix though as a new module is gonna cost me $175.
Mar 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Feb 17, 2008 | Bosch SHU9950 Dishwasher
Access controls
screw driver hex#15
Oct 27, 2007 | Bosch SHU9950 Dishwasher
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
