Samsung sf- 360 - removing jammed paper
Hi!
My name is Diana
I can' t remove the jammed paper from my fax samsung sf - 360, because I don't see any jammed paper.
Can you help me, please?
Thank you soo much!
Hi DIANA,
IN CASE YOU CAN'T SEE ANY PAPER , THE CARTRIDGE CLEANING ASSEMBLY IS BAD , PLEASE CLEAN THE SENSOR IN THE SAME WITH IP ALCOHOL OR REPLACE THE SAME . THE PROBLEM WILL GET RESOLVED .YOU WILL NEED SOMEBODY TECHNICAL TO DO THE JOB.
HAPPY FAXING,
OMNI, INDIA
Posted on Jun 14, 2008
    Genius:
  • 2,985 Answers
There may be a small piece of torn paper holding the sensor.
1. Try loading a piece of paper and selecting 'paper feed'
It may take a couple of goes.
2. Try the same with thin card.
3. with the machine switched on remove the power cord.
4 Discover the 'Reset' routine for this particular machine.- It may be
in the manual if not look up www.fixyourownprinter.com
then in the field type the make/model
Fax machine problems
Unplug the device from the AC power for about 30 minutes to allow it to reset the circuity.
Hope this helps.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung SF-560R display "DOOR OPEN"
Check the cartridge and for a paper jam in front of fax.
Jul 29, 2011 | Samsung SF-560 Plain Paper Laser Fax
It say paper jam and ther is no paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 31, 2009 | Samsung SF-335T Plain Paper Inkjet Fax
Remove jammed paper
I had the same problem.
I found that the gears driving the printhead cleaning mechanism was jammed.
To solve this, I removed the top cover (6 screws and a clip centre bottom, back).
Please take care when working on the Fax machine as there are high voltages present.
It is best to always remove the power sorce when working on electronic equipment.
I removed the cleaning mechanism (2 screws)(you have to remove the circuit board next to it to get to the one screw). I did not disconnect the ribbon cable from the circuit board, only the two smaller cables.
Once removed, I gently tried to rotate the cleaning mechanism by turning the plastic gears. It should rotate freely by 360 degrees. If it sticks at all, there is most probably some dirt stuck to one of the gears. Using a magnifying glass, carefully inspect the gears for dirt and gently remove the dirt with something thin and pointy like a bag needle. Be sure to check that the gears are still adequately covered in grease afterwards.
Reassemble and test before fitting the top cover.
I do not know why they set the fax up to give a paper jam when this item jams but this was the problem on my fax.
Good luck and I hope this solves your problem.
Regards,
Gary
Jan 21, 2009 | Samsung SF-335T Plain Paper Inkjet Fax
SF-341P
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Oct 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Samsung fax machine SF-365TP
Before diagnose the problem please turn off the Machine.
Check all sensor if they have dust then clean it.
Close properly the cover.
Sep 15, 2008 | Samsung Office Equipment & Supplies
Paper jumped problem
Do you mean jammed?
Usually they don't lie. A piece of paper is somewhere.
Apr 09, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
SAMSUNG SF 360....connects but doesn't send
I Strongly suspect phone line.
If is it a DSL line you may need to filter is. If it is a digital line, then you shold switch to analogue.
I would start by just replacing the phone cord between the machine and the jack.
My other question is, are there any other devices plugged into the same phone line with the fax machine. A credit card reader, an answering machine? If so try removing them and see if there is some problem with a shared line.
But more then likely, you have a line with static, a bad groung. Low phone line voltage, current. some other line issue is very possible.
Suspect strongly a phone line issue
Mar 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
No receiving fax
Make sure there is paper loaded and there is not a jam any where in the machine. Also check you r receiving settings
Jun 05, 2007 | Samsung SF-3100 Plain Paper Inkjet Fax
418 people viewed this question
jasbo
jasbo
