Question about Samsung AH5901169L Remote Control
What is the similar remote of samsung bn59-00960a(samsung color tv) remote model please suggest
  • 12 Answers
SOURCE: i have a samsung bn59-00599a remote for samsung
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
SOURCE: samsung bn59-00599a remote
Cable - set - 038 Power Worked for me, hopefully will work for you as well.
Posted on Jun 22, 2008
SOURCE: my samsung remote bn59-00673a does not work at all
"The Samsung Website says to take the batteries out and either press the reset button for 2-3 seconds or hold down the power button for 1 minute.
Got to say I was sceptical but it worked!! "
from http://www.fixya.com/support/t952131-samsung_bn59_00463a_remote_doesnt
Posted on Aug 03, 2009
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Posted on Oct 27, 2009
  • 1335 Answers
SOURCE: my samsung remote BN59-00852A just stopped
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
Posted on Feb 03, 2011
Can the Samsung AK59 remote control other tv features?
That is a DVD remote and it appears only to control the volume and power on the TV. the other controls are for the DVD player.
The link below shows how to program a similar remote and may help. Programming The Blu ray Remote To Control Your TV
Mar 02, 2018 | Samsung Televison & Video
Why is our LCD Samsung TV turning itself on and off on it' own?
is there another remote nearby affecting your TV? Look for patterns like time of day or check similar remotes when activating various items. A lot of tech runs on similar bands.
Jan 22, 2015 | Samsung Televison & Video
Please assist. How do I set my screen smaller on my Samsung BN59-00890A with my remote.
I think you are quoting the Remote Control number. What is the model number of your TV?
Jan 15, 2015 | Samsung Televison & Video
Just moved and lost my samsung remote. I have direct tv but I'd like to watch movies. Will a universal remote fix my problem? Also, where is the model number on a samsung LCD tv.
The model number (label) is usually located either on the back of the TV, or on the r/hand side of the TV.
To obtain the best from your set, you ideally want the original factory remote. However, some Samsung remotes share the same functions.
Generally, the remotes are specific to each brand, but some brands of remotes have been known to transmit similar frequencies (i.e. Philips & Samsung).
You can only use a Universal remote, if the remote supports the Samsung programming codes (check the remote's user guide to see if Samsung codes are supported).
Cheers,
Sep 04, 2011 | Samsung Televison & Video
Samsung LN46C530 TV. Have had the TV around 1.5 months. It appears that the remote sensor on the television has stopped working. Both remotes work but the TV doesn't read them. Is there a quick fix for...
G'Day
I have a similar Samsung set... and found that the remote sensor is rather low gain. I noticed the same thing when I first got the set. The remote did not seem to work. Pointing it directly at the right side corner at the power light of the set seemed to allow it to work. 10 degrees away from that either side and it does not work. I also had 2 remotes that behaved in a similar manner(got an additional free 22" set with my purchase). I also suggest changing the batteries out as the ones supplied with the set are generally low brand,and may not last that long.
Other than that, you may need to contact Samsung service to have the set replaced/repaired. Your best point of contact here is the retailer that sold you the set. If they cannot arrange for the repairs for you, let me know where in the world you are, and i will get a contact number for you.
regards robotek
Aug 31, 2010 | Samsung LN46C530 TV
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Setting up a universal remote
Whats the brand of universal remote?
If you have the original remote I can suggest some learning remotes that will absolutly work with it.
Cheers,
Jan 06, 2010 | Zenith Televison & Video
CCA Values For Samsung TV
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Jun 11, 2008 | Samsung Televison & Video
Samsung TV with RCA DVD Remote
could you specify what is your RCA remote model ...? and this is a page that have all RCA codes .... http://www.thompsontv.com/rcarc.html please rate me if this help you !
May 31, 2007 | Jensen JR500 Remote Control
Samsung AH5901169L Remote Control Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
