Question about Malber TD700 Electric Dryer
Quit working----we thought it was a motor---took motor off---it runs
  • 1,531 Answers
If the heat has stopped check the main power and make sure there is 220 volts at the terminal block.
if the power is correct then next thing is to check the continuity of the heating element,and all the thermal cut offs if you find one of them with out continuity then replace that part.there is also a chance the main control board has failed as well as the door switch this also needs to be checked.
Posted on Nov 03, 2010
Fan for air conditioner and heat runs only part of the time
check whether the fuse is connected properly.check any loose connection.keep me updated for further sugestion
Aug 15, 2008 | 1995 Jeep Grand Cherokee
Just replaced the wiper motor on Jetta and wipers still won't work
Have you replaced only the motor or including the gear box (where the input shaft to the linkages is located)?
Oct 23, 2012 | 1999 Volkswagen Jetta
Hi, I have a 2004 Vulcan Nomad 1500 L5 FI. I'm having issues starting the bike after I've been out riding for a while. It always took 2 or 3 revolutions (?) to start, but last season it sometimes took 4...
Hi
I would check the connection between the battery and the starter motor although its quite feasable that your starter is worn and is loading up, which makes it slow to turn and require more power from the battery.
Maybe you can remove the starter motor for testing?
Apr 24, 2017 | 2004 kawasaki VN 1500 Vulcan Classic
Took our 2001 Caravan SE to local mechanic because rear wiper quit working. They diagosed proble as faulty PCM. Thought they were doing us a favour by putting in a used one from a 2002 that they thought...
i dont see why they would diag the pcm for the rear wiper, power from fuse to switch to wiper!! no pcm in between this operation. I would have had this fixed in a hour. Have mechanic pay for the bill to get it running. It was running fine when you took it there and only the rear wiper didnt work and now you are out of a vehicle and a tow bill at a hourly dealer cost. Best of luck to you 300.00 later.
Jan 29, 2011 | 2001 Dodge Caravan
I have a Kenmore 54701 Dehumidifer that quit working is there any thing to look for or just throw it out and buy a new one
Is it not powering at all? Remove cabinet and check glass fuse on power supply board
Is it running but no water?
Check to see if fan is blowing; if not then thermosenser on fan motor blown
Fan and compressor running but no water? Maybe the room is already dry; if not than probably have coolant leak - not worth fixing
Dec 04, 2009 | Kenmore 54701 Dehumidifier
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Intermitten A/C problem on my 1995 suburban
Unfortunately, the A/C systems on the GMT400 (92-99) GM SUV's were not particularly reliable. A fuse may have blown (unlikely), compresser may be bad, the condensor could be out, or the entire system may need replacement.
My advice? Take it to a different mechanic, or a dealer.
Oct 26, 2008 | 1995 Chevrolet Suburban
3.0 h.p. wet/dry vac
Check the motor brushes, either worn down or dust is keeping one of them from laying on the armature. The other would be a bad motor.
Jan 13, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Malber TD700 Electric Dryer Logo
88 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
jimorris77
ray gallant
Are you a Malber Dryer Expert? Answer questions, earn points and help others
