Question about Maytag PAV2300 Top Load Washer
Washer seems to work, but will not spin. - Maytag PAV2300 Top Load Washer
  • 1,531 Answers
You can use a wet dry shop vac and attach it to the maindrain hose to remove the water.once the water is removed then you can tilt the washer back wards and look at the transmission coupler.it is white and black and located in between the trans mission and the back of the motor.you will be able to tell if it is broken.
there is a chance the lid switch is faulty,and or the transmission.there is a capacitor located on the back wall on the inside of the cabinet that may be bad but at this time i dont believe so.
Posted on Nov 03, 2010
When the washer gets to the spin cycle it seems to stop and not pump out the water. All other cycles seem to work ok. It is a GE spacemaster 22"
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | GE Spacemaker WSLP1100D Top Load Washer
SPIN CYCLE DOES NOT SEEM TO WORK. WAS NOT
There is a drain in the bottom of the washer. Remove the front panel...you will see the pump. Drop the line - it is probably FULL of trash - so full that the washer can't drain. The first time it happened, I paid a $200.00 repair bill. Second time, I cleared it in 5 minutes. If you call a repair man.....watch what he/she does!
Mallie
Jun 16, 2009 | GE WSXH208A Front Load Washer
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer doesn't reliably spin dry clothes
more than likely your carbon brushes which are situated in your motor locatable by a single wire on each side of your motor going into a plastic casing that holds the carbon if it doesnt have carbon brushes than it will have a module which is about 4in in length and is a circuit board this will need replacing which in some cases is not cheap at all
Aug 15, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
