Question about Magellan Meridian Gold GPS Receiver
Meridian gold problems
My magellan meridian gold does not work
it shows scren PRESS ENTER TO AGREE and after that turns off no mater what i press
  • ledford Jul 23, 2008
    I have the same problem. After leaving my GPS in my boat for the winter, it took a long time to boot on 12V, then would not lock on to the satellites. It displayed wrong info, then when I tried to use the menu, it crashed. Now it won't boot up at all. 5 seconds on the power button does nothing.
Mine pulled the same act not too long after I got it, so it was under warranty. I sent it back to Thales Navigation, and they fixed it for free. It had "died" while I was acknowledging a "LOW BATTERY" alarm. I've now had mine for at least two years, and no recurrence of such a serious brain cramp. That was pretty annoyin' when it happened.
Posted on Nov 09, 2008
Netopir, I assume you have tried replacing batteries at least a couple times?
I wonder if tedford has corrosion inside his unit. The Gold has a rubber gasket and is a bit water resistant, but high humidity and salt water exposure would take a toll on the electronics inside.
Posted on Oct 10, 2008
My Magellan Meridian Gold GPS works with a car cradle but does not power up with its own battery power. How can I fix my receiver to work with its batteries?
You may find the problem is with the connections from the battery to the circuit board.
Take the back off and check the battery connectors where they contact the board. They may need cleaning or re aligning
Mar 10, 2010 | Magellan Meridian Gold GPS Receiver
Magellan Meridian Platinum needs to be reprogramed.
http://sites.google.com/site/rayjeromejobs/magellanwaasfix
Mar 01, 2010 | Magellan Meridian Gold GPS Receiver
How do you set waypoints on the Magellan Meridian gold. To and from a location?
Press and hold the GOTO button for 2 seconds. A "Mark" screen will appear. If you are saving your current location, highlight the "Save" at bottom of screen and press enter. This will save you current location. You can edit the name of the waypoint at this screen also. You can do this before you save the waypoint or you can go to Menu/Database/User/Waypoint (the one you want to edit)/Enter. At this screen you can edit the name by pressing the arrow up or down to get to the name field and press "enter" to get to the alphabet screen. If you are entering a waypoint using coordinates, do the above but edit the coordinates to the ones you want to use and then save.
Sep 30, 2009 | Magellan Meridian Gold GPS Receiver
Wont power up
This may help. I have had the same problem from time to time. I took the back off ( slowly don't break the four wires connected to the back) then I cleaned the connections where the battery pins press to the main board.
Jun 12, 2009 | Magellan Meridian Gold GPS Receiver
Where can I get a users manual?
http://www.magellangps.com/assets/manuals/Meridian_series_en.pdf
May 18, 2009 | Magellan Meridian Gold GPS Receiver
My magellan meridian gold does not turn on ,,and if it does the screen is all blue
The unit is coming on but the LCD display has Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} separated and needs replaced.
Apr 23, 2009 | Magellan Meridian Gold GPS Receiver
How to use sd card with magellan meridian gold
http://www.mtgc.org/robertlipe/MeridianFAQ/#47.Troubleshooting%20–%20My%20tracks%20have%20the%20wrong%20time%20stamp?|outline
Try this site to trouble shoot your problem! Good Luck! I ran across this today trying to trouble shoot mine.
Dave
Sep 09, 2008 | Magellan Meridian Gold GPS Receiver
Deprogramed
I need more info to possibly help.
Do you have info on the SD card you need to keep?(just use a SD card reader for your computer to reformat to FAT) Be sure to copy all files to a safe place FIRST!
You could also try this combination, to clear ALL memory then reboot GPS unit.
1. Press and hold "Enter"+"Menu"+"PWR"
2. Follow GPS units On-Screen directions.
If GPS unit "locks-up" press and hold keys in this order, "Goto"+"ESC"+"Enter".(Forces GPS unit Off)
good luck
Aug 08, 2008 | Magellan Meridian Gold GPS Receiver
Power on
Hi.. I also have the same GPS that you have, try to press the power button for 5 second and release it.
If it does'nt power up with a new batteries i think there's a problem inside the unit.
Hope it helps..
Enjoy!
Pls. Rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Magellan Meridian Gold GPS Receiver
I unscrewed the 6 screws holding the back to the Meridian Gold unit and looked at the contacts. I noticed that one of the curved prongs that makes contact from the battery to the unit was bent low so I knew it was not making contact and preventing the unit from working. So I very gently took the small screwdriver and pulled it out a bit so that contact was the same height as the other. Screwed the back back on, reinstalled the batteries, presto - works like a charm now. Anyone can do it.
Now I need someone to tell me what alternative GPS map packages giv e the most bang for the buck as my Map Send CDs were accidently thrown out by a well meaning person cleaning up my desk....
Jun 12, 2007 | Magellan Meridian Gold GPS Receiver
Magellan Meridian Gold GPS Receiver Logo
150 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
