Question about Protron PLTV-37 37 in. LCD Television
Connecting laptop to LCD - Protron PLTV-37 37 in. LCD Television
  • 3 Answers
Get adapter from hdmi to you computer on fryz
Posted on Nov 03, 2010
I would like to connect my Toshiba satellite C650D 026 laptop to a Panasonic LCD TV what do I need?
if you have HDMI port on your laptop connect it through that or connect it through the vga port of the laptop to the lcd
Feb 02, 2013 | Computers & Internet
To connect with lcd with hdmi
Looks like your laptop has a HDMI port. Simply connect to LCD (HDMI if supported) port and make sure LCD is set to correct input (HDMI). It should be plug and play, but try connecting and then powering laptop, then LCD, then choosing input port on LCD.
Sep 30, 2012 | Lenovo IdeaPad Z560 Notebook
How to connect laptop to LG 65LM 2500-TA
that" easy thing. first you need to check both of them --- lcd tv &laptop what kind connection have ? hdmi ? vga? rca? to find out which one. then you use one side connect to lcd tv . another side connect to laptop. & you need to sellect which one input for lcd tv. that" s it . good luck!
Sep 07, 2012 | LG 65LM6200 65 Inch 3D 1080p 120Hz Smart...
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
Feb 23, 2011 | HP G60-120US Laptop
My LCD monitor is white when i work?
I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen
Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard
The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
Hope it helps, else you will have to send the system for servicing to the manufacturer
Regards
Jan 27, 2011 | Acer Aspire 4315 Notebook
The display turn white >>>what can i do?
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Jan 18, 2010 | Samsung NC10-14GW Notebook
When I turn on the computer the screen is white but the computer is booting up.
CONCLUSION.
Jan 14, 2010 | Dell Studio 17 Laptop
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Getting audio from a Dell LCD Monitor when connected to a Laptop
connect the audio cable to laptop and LCD monitor...
.35mm male to male jack
connect the cable to your laptops headphone jack and the other end of cable to the monitor
the VGA and DVI cable are for video only
Apr 02, 2009 | Computers & Internet
Connecting my laptop to my samsung lcd tv.
If you know how to let it work with an LCD or DLP projector then all you have to do is set the selector of the your LCD TV to the RGB or computer input. If not, then you have to hit the function key in order to activate the secondary port for the external display of your laptop.
Jan 11, 2009 | Acer TravelMate 4200 Notebook
Protron PLTV-37 37 in. LCD Television Logo
26 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
