Need a replacement exhaust fan motor. - Heating & Cooling
    Brigadier General:
  • 3,917 Answers
Please check the bellow links for the replacement parts....
http://www.globalsources.com/manufacturers/Exhaust-Fan-Motor.html
http://www.homeadditionplus.com/Electrical%20Articles/Replacing-a-Bathroom-Exhaust-Fans-Motor.htm
http://www.electricmotorwarehouse.com/aosmith/nutone/nutone.htm
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Nov 03, 2010
Need replacement motor for bath exhaust fan.
Best place usually is grangers if you just need a motor. Take in motor and they can match up the exactone for you.
Jun 09, 2015 | Patton Dryers
LIGHT, turntable, and fan don't come on
follow this test and fix it. God bless you
  1. Exhaust fan motor If your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. Thermostat Another part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control board If your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Dec 09, 2013 | GE CVM2072SMSS Microwave Oven
Fan running when door open
measure this test and use the multimeter for fix it. GOD BLESS YOU
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Nov 08, 2013 | GE JVM2070 Microwave Oven
Fan starts when i open door
follow this test and use the multimeter and fix it. God bless you
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
Oct 24, 2013 | Frigidaire Microwave Ovens
The vent fan is not working but micro is. Replaced charcoal filter & reset still not working.
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
We changed the charcoal filter & reset it. The vent fan still does not run. I cannot turn the vent on by pressing the vent button but the micro still heats up. What happened to the fan?
follow this steps and fix iT. God bless you
My 900 em do oven keeps over heating and switching off
follow thes steps and fix it.God bless you
Exhaust Fan Motor
If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it doesn't, replace it.
Thermostat
If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board
If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.1_24_2013_5_50_54_pm.gif1_24_2013_5_53_00_pm.jpg
Jan 24, 2013 | Microwave Ovens
I need a replacement motor for a NuTone Model LS-80SE exhaust fan but can't find one.
Home depot usually has a good selection of replacement fans. They usually are a fan on a mounting plate, not just the fan motor itself. Sometimes you have to purchase the entire fan unit just to get the fan motor plate inside for a replacement part.
Feb 23, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
Heating & Cooling Logo
267 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
