Question about Refrigerators
Evaporator fan motor kit Gasket/door f.F. Gasket - door frezer
    Guru:
  • 1,524 Answers
Need these call Bi Coastal Appliance Parts
Posted on Nov 03, 2010
Refridgerator has started making a noise. It stops when I open the refridgerator door and then starts again when I close the door.
It's your evaporator fan that is either hitting frost build up or bearing in motor is bad. If blade is hitting frost, you may have a defrost circuitry problem or door gasket problem
Jul 31, 2015 | GE GBS22HCP Bottom Freezer Refrigerator
Makes a loud noise when doors are shut but shuts off when door is open
Thank you for contacting fixya.com.
Check the door gasket or the hinge those can get loose. When the door is opened and closed you change the air pressure in the fridge/freezer so you may have a leak in the gasket. You also change the air pressure to the evaporator fan which supplies air from the freezer to the refrigerator so you may have a bad evaporator fan motor.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Samsung RF265AA Bottom Freezer French Door...
Alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Mar 01, 2010 | Liebherr Refrigerators
The freezer works but the refigerator section does not. When you turn the temp switch for the refrigerator it will turn off the freezer also.
dont tuch the thermostat put it in normal setting!
now, check if your fan in the frezer working, if it is working che3ck the thermostat unit and heater in the frezer unit also need to see if the frosting is eaven all over in the frezer side..
contact me at www.911servicetoday.com
Dec 30, 2009 | Refrigerators
New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Tow dooe refrigerator and frezer, ice in the
likely door gasket door out of alignment. or the defrost high limit switch is not opening in defrost when the evaporator get warm during defrost check the door gaskets good and clean. Tom
Jun 29, 2009 | Refrigerators
Refrigerator not getting any air, (it is warm), freezer seems ok
so you mean the vents in the refer/frezer sections? yes ok there is a fan in the frezer section that moves the air thru out the box.its called the evaporator fan.you should hear a vissssss sound when you open the doors.some boxes you have to push the door switch closed with finger because fan goes off win door open.test fan with volt meter,should get 110 volts[may have to push that door switch in when testing]if voltage and not turning get new fan.hope that helps God bless ,tom
Jan 05, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
