Question about Hitachi 53UWX10B 53" Rear Projection Television
Progress Slinte, You were right, the wire connectors (4) that connect the conv bd to the center bd(horiz?) #3 from back or #2 from front was bowed, after reseating it, sound and video came back, but the video was real dark, this is where your excellent knowledge,advice & expertise couldnt help me. I got excited feeling victory and felt I needed only brightness, I went for the screen/focus controls, bad move, the second I touched the red focus VR it started chirping with the flashing power LED again, so Im looking for chips again. I sincerely want to thank you for being there.
  • Butchilee Sep 03, 2008
    I took a break from this(pos), but after replacing the ICs again
    using the 160s, sound and pic came back with terrible convergence, that the service switch has no effect nor does the
    majic focus.
    I asked you guys about the sound of letting air out of a tire after a IC replacement earlier, well I stumbled up on the cause of it, the socks were blown off of CK05(470uf/16v) electrolytic in the
    emitter circuit of QK01(2SC3852) npn,this along with IK01 and electrolytic caps in the + and - 5volt regulator circuit.
    Anyone with knowledge of this circuit, holler, butchilee
  • Hitachi Master
  • 8,617 Answers
I would check the red CRT PC Board for a bad connection on the socket. The focus wire plugs into that socket. And a corroded socket, cracked solder or a faulty focus lead connection can cause that symptom.
Posted on Jun 13, 2008
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
Sep 11, 2016 | Panasonic Audio Players & Recorders
I am having trouble fiquiring out which wire goes to which plug. The wires are different lengths and the correct wire length has to go specifically with the correct plug. I have the firing order dia
The firing order is 1-2-3-4-5-6
Cyl #1 is front left when looking at engine front to back
left coil pack connects to cyls. 5-2
center coil pack connects to cyls. 3-6
right coil pack connects to cyls. 4-1
It doesn't matter which connector on the coil you use just that the cylinder is connected to the proper coil pack (the coil fires both plugs at the same time, twice per each full 4 stroke cycle)
1998 Chevrolet Lumina
Dec 20, 2013 | 1998 Chevrolet Lumina
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
I need the firing order for spark plug wires for 1998 ford explorer
V6
Firing order 1-4-2-5-3-6
cylinder numbers
firewall
123
456
front of car
________
465
321
>wire<
>connector<
Mar 25, 2010 | 1996 Ford Contour
Order to put wires on nissan maxima
For the 1993 Nissan Maxixa 3.0L:
Firing Order:
1-2-3-4-5-6
Cylinders:
......(back)
1.......3........5
2.......4........6
......(front)
Distributor Connections:
...(back)
............1
......6
5.................2
............3
......4
..(front)
Oct 20, 2009 | 1993 Nissan Maxima
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
89 ford mustang convertible
This is a professional job for a conv. top shop. has to be sewn in at the bottom.
Removal
NOTE: Mark vinyl to be removed so it can be returned to the same position after disassembly.
  1. Remove sail area panels as outlined.
  1. Remove staples retaining elastic straps at each side of back window glass (42006) to rear tacking strip and folding top rear number 4 bow (51278) and remove elastic straps.
  1. Remove staples retaining rear bow corner pad (537A71) and bottom of folding top back window curtain (52500) to rear tacking strips.
  1. Remove staples retaining top of folding top back window curtain to folding top rear number 4 bow and remove back window glass .
1994 mustang. don't have 89 Window, Rear Installation
NOTE: Transfer markings from the removed assembly.
  1. Mark with grease pencil center point on folding top rear number 4 bow in line with hole on rear of folding top rear number 4 bow .
Oct 07, 2008 | 1989 Ford Mustang
Error code dl then f
sounds like door lock issue but probably not lock itself remove top (3 screws) along back of top ..at rear of machine is control board ..if you are hearing a clicking noise at time door is supposed to be locking try wiggling connectors on control bd if i remember they are the pink wires if door locks then you have a bad connection on control bd may try wedging something under connector to help hold in place but only true fix is a control bd..good luck
Jun 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
