Question about GE Heating & Cooling
Would like to get a manual for an APE08AJM1 115 volts 8000 BTU room airconditioner 20RJ UL File NO. SA 11094.
koolbreezes
  • 540 Answers
SOURCE: Not removing humidity
Just adjust the thermostat lower or colder!
Posted on Sep 05, 2008
tebot
  • 15 Answers
SOURCE: GE ASM10AK 10,200 BTU Room Air Conditioner is 115
It would be easier to change the 220 circuit in your house to a 110 by some creative work in the breaker panel and making it an air condtioner circuit only. You would need to check with an electrician, but would probably be worth it in the long run.
Posted on Mar 29, 2009
SOURCE: max size room for effective cooling?
20 x 20 = 400 square feet
Posted on May 08, 2009
  • 3 Answers
SOURCE: How many BTUs does this unit have?
The M3X05F2A is a 5000 BTU unit.
Posted on Jun 16, 2009
  • 5679 Answers
SOURCE: no problem..just needing a manual
GE has the manual on the product site: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=APE08AK . See the Literature and Manuals section on the left side of the page below the product pictures. The direct link to the manual is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-7563.pdf .
I hope this helps.
Posted on Sep 02, 2011
NEED HELP TO REPLACE WIRES ON CAPACITOR ON GE ROOM AIR CONDITIONER 8000 BTU
with capacitors it doesn't matter which wire goes on which terminal
if it has just 2 terminals then a wire on each
if it has 4 terminals then one wire on one set and the other wire on the other set
A set is two terminals side by side
However if you are still undecided , get an electrician to fit the wires.
May 09, 2015 | General Electric GE AEM08LQ 8000 BTU...
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
Do you have a manual written in English for the AC listed.
This is just a world wide free chat room
There is no one at FixYa answering anything
Just people at home like Facebook
So call the company or use the internet to
find a manual online
Jun 02, 2014 | Soleus 8000 BTU Evaporative Portable Air...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have an older 8000 btu unit - i have no manual. its 98 outside - when i start up this unit , should i have it on hi- med - or lo ? if i run it too hard will i freeze it up?
If everything is clean and the unit is properly charged with freon then it should not freeze up and I would start it anywhere you want to as that just controls the fan speed. It's108 here. Best of luck and thank you.
Jul 22, 2011 | Kenmore 8,000 BTU Single Room Air...
I have a single room 8000 btu kennmore air conditoner was making loud squealing noise when compressor kicks on and now it makes no noise and does not cool at all please help
sounds like the compressor may have died on you. the compressor isnt running you might as well trash it sorry for the bad news but it probably isnt worth trying to replace a compressor in a system like that it would drive you crazy and take forever if it could even be done.
Sep 17, 2009 | Kenmore 8000 BTU Single Room Air...
Sep 05, 2008 | Frigidaire FAH085N1T Air Conditioner
Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Heating & Cooling Logo
85 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
