Question about NEC MultiSync VT45 Multimedia Projector
Replacement bulb for nec vt45
I want to purchase a new bulb but when i go to order one the pictures it shows me look nothing like the bulb took. it says the lamp type is vt45LP! I can only find lpk ones but the power connectors look like there on the wrong side but all the picd are poor quality. can anyone help.
Cheers
3 Suggested Answers
SOURCE: Flashing red status light on NEC VT45 projector
Press and hold down the help button on the remote pointing it towards the projector for at least 10 secs.
Posted on Mar 03, 2008
informatica
  • 1113 Answers
SOURCE: Resetting Lamp Hours Procedure On Nec-MT-1075
Hi - You can download the manual by clicking the link underlined in blue below:
Nec-MT-1075
See page E-55:
As in the note replacing the lamp automatically clears the lamp hours.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 05, 2008
projdoc
  • 2236 Answers
SOURCE: Steady red status light on NEC VT45 projector.
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Posted on Dec 16, 2009
I have a NEC VT700 projector. I replaced the bulb and housing because it would no longer turn on and the status light would blink every 2.5 seconds indicating the housing on the lamp had an issue. I...
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
Jan 12, 2011 | NEC VT700 Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Light and fan will not turn on.
the temp sesor may be defective. check fuse or relay
Sep 19, 2009 | NEC MultiSync VT45 Multimedia Projector
Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Mar 23, 2009 | NEC VT676 Multimedia Projector
NEC LT265 Multimedia Projector will turn on, but does not fire up
the bulb needs to be resetted after fixed or the other problem is that the bulb is not fixed.or the ballast is faulty. check out all the options 1 by 1 in the given link how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | NEC LT265 Multimedia Projector
NEC Overhead Projector
Hi Forrest
This sounds like a damaged Mainboard.
First check if your Projector is still under warranty as this is a very expensive part to have replaced.
Also check if it has any effect whatsoever using another PC Cable.
Hope this is of help.
Mar 29, 2008 | NEC VT47 Multimedia Projector
The picture shows dark
Hi there
Take out the Projector's lamp and check for any black marks ( almost looks like veins ) on the inside of the bulb.
If you spot anything on the lamp , your lamp will need replacement.
If you can't see anything - then you might be in for a new Mainboard.
Very expensive exercise !
Mar 11, 2008 | NEC VT47 Multimedia Projector
make sure the doors are shut all the way! there is a little button there.
Feb 13, 2007 | NEC MultiSync VT45 Multimedia Projector
NEC MultiSync VT45 Multimedia Projector Logo
106 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
