Question about MSI PM8M-V Motherboard
No display Hi, there is no additional graphics card, only onboard graphics, so it cant be that.
HI IWANT DRIVERS MY M.B MSI
Posted on Jul 01, 2008
  • 84 Answers
Is it booting up ? if so, try to press F2 of del, then check the vga setting there, enabe the on board settings, please let me know if this work.
Posted on Jun 27, 2008
  • A Vallescas Jul 09, 2008
    try to check the led light of your computer if its blinking in red, if so you need to configure the vga setting in the bios set up. if its not blinkin gin red, then your hard disk failed.
No video signal on acer aspire x1200. changed monitors and cables
You should be more specific next time - is it a laptop or a desktop computer, do you have additional graphics card, etc? I've already googled for a PC type. You have a desktop PC which comes with integrated graphics. It has two video ports onboard - VGA and HDMI. Which one did you try? It could also be that you have additional graphics card installed. In this case integrated graphics card is turned off automatically. Sometimes people accidentally connect their display to the wrong port - you should check that. It could also be, that you don't see any video output, because of faulty hardware like RAM, CPU or the Motherboard. Do you hear any beeps or other sounds during startup?
Oct 15, 2012 | Acer Aspire X1200 PC Desktop
No display
Your system is not receiving the POST signal from your motherboard. Make sure you have connected the display cable either to your onboard graphics or your graphics card.
If you previously had your VGA cable connected to a graphics card, remove the card and plug into your onboard graphics. Then power up and see if you get signal.
If you get signal after plugging into onboard graphics then this means that your graphics card has failed and you will need a new one.
If you still don't get signal then you will need to take your system to have it checked out by a qualified PC technition to see which components have failed.
Feb 14, 2011 | Intel D845GVSR Motherboard
I have upgraded to windows 7 32 bit prof and it doesnt seem to recognise my fx graphics card (quadro fx 3000) tried to download drivers from nvidia and got two varyents 259.81 and 266.45 and when i try to...
Hi there,You need to disable your Onboard(defualt-built in) graphics card first,by going into device manager->display adapters->''whatever the name of your previous video card is'' and right click and then click disable hardware..Good luck
Feb 05, 2011 | PNY Quadro FX 3000 (256 MB) Graphic Card
Geforce Cant working on pc
1st you should disable your onboard display card from the BIOS setup. Then Your PCI Card will show display.
Jan 09, 2010 | Computers & Internet
Asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a while and then shows the same problems.tried different graphic cards and get same result or would show all...
http://www.asrock.com/mb/download.asp?Model=Wolfdale1333-D667&s=775
Select your operating system. If this model has onboard graphics, download fresh VGA driver, remove your graphics card and see if you can get any results.
Nov 23, 2009 | Computers & Internet
Hi, i ve intel 82865G motherbord. i want to add additional grafiX card to it can u help me??
just buy a graphic crd u want 2 use on it. add on ur board, and go 2 bios with push del on d kboard. then, turn off primary graphic card. if windows detect ur new grapich card, plz install w a CD of ur new graphic card. ones more don't frget 2 turn off the primary graphic card onboard first...
see ya...
Jan 26, 2009 | Computers & Internet
Dual monitor
Depending on the exact model Radeon card. If you mean to dual display with onboard and with the card. That is not possible it can not be done.
If you need further assistance please let me know.
Lee
Jun 18, 2008 | HP dc7800p Business Desktop USDT
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Disabling the onboard graphics for this motherboard
hi, go to system bios, i think in the second options check out for primary display , you will have options for add on, or onboard, change it to add on, or there is also an option to disable the primary display somewhere there, browse the bios around , you will find either of it. let me know
Dec 16, 2007 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
Nov 24, 2007 | Dell Dimension 2400 PC Desktop
MSI PM8M-V Motherboard Logo
96 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
