Question about Kitchen Ranges
Coffee maker will power on, but not heat and then shuts off???
Its electric heater may be faulty thats why its suddenly get off.change the same
Posted on Nov 03, 2010
My cuisinart coffee maker shuts off after brewing cycle. What. Do I do to fix this oroblem
Unplug the coffee maker for about half an hour, then plug it back in. That will reset the microcontroller inside the coffee maker. This will eliminate the early shutdown problem.
Oct 12, 2014 | Cuisinart Coffee Makers & Espresso...
Water in resovoir boils away. Do I need a thermostat?
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
Dec 02, 2009 | Bunn VPS Coffee Maker
Mini brewer shuts off wont heat up wont make coffee Light goes off after cup is placed to catch coffee wont heat or make coffee
thow it on the ground and stom on it. if its not working now theres nothing you can do. Take it to the dump
Jun 28, 2009 | Keurig Ultra B50 1-Cup Coffee Maker
Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Jan 31, 2009 | Cuisinart DGB-300 Coffee Maker
Element won't get hot, used multimeter seems circuit board is no allowing element to heat,
I have the same problem.
I disassembled the bottom of the coffee maker, and unscrewed
the bracket holding the circuit card.
I cut the input power and ground wires from the plug to the card, and detached its modular wire for the heating element.
I removed the card (to take to lab for further debugging).
Then I bought some .25 inch modular tab connectors at the hardware store and attached one to the power wire formerly going to the circuit card. I attached this to the heating element.
I covered the spare ground wire with electric tape.
Now I have a coffee maker which brews coffee again (except that I must pull the plug to shut it off). I must be careful not to let the
water boil away, but that is usually not a problem.
If I figure out what is wrong with the circuit card, I will update you.
It has a microprocessor, and I am not optimistic about replacing
that (with the right program in it). If it is the triac (the component
with the big block heat sink), it can be done.
Jan 09, 2009 | DeLonghi DCU72 Coffee Maker
Delonghi DCU72 refused to heat on 6th use.
Being an electrical engineer, I would like to debug the circuit card.
However, I would like to brew coffee also.
I cut the input power and ground wires from the plug to the card, and detached its modular wire to the heating element.
I removed the card
Aug 26, 2008 | DeLonghi DCU72 Coffee Maker
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
I have a problem wih me coffee maker
While bikeman's fix was helpful and sure enough got the coffee maker to brew me one last pot of coffee it was also a sure FIRE method for creating a counter top electrical fire!
I followed the solution's directions to the letter and when the pot of coffee was finished brewing the heating element did of course keep heating to the point of bursting into a small electrical fire and melting plastic to my counter top.
I pushed the off button and unplugged the coffee maker and brought it outdoors to cool off before discarding.
While it is a solution it is a VERY DANGEROUS SOLUTION!
I would suggest that anyone who does not have the $20 to replace their broken coffee maker to either buy a replacement over heat sensor or get their brew from a nearby Deli!
Seriously folks this repair is clearly asking for a house fire!
BEWARE!
If one were to maybe shut off the maker instantly after a pot was made
Jan 09, 2008 | Black & Decker SmartBrew DCM500 Coffee...
Delonghi Coffee Maker
You need to take the unit to an authorized repair shop and have the heating element replaced
Sep 01, 2007 | DeLonghi DCM485 Coffee Maker
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
