Question about GE WBB4500EWW Top Load Washer
Kinked hose or blockage in the water pump you defininatley have material in the water pump
disconnect washer all together pull out after you drain the water by hand as far as can go use a dolly take out side drain the rest by tipping on side you might need 2 or 3 people to get the washer out with little water left when on side pull the water pump off look inside and pull material out with a pair of needle nose pliars that clamp you will need 2 people to pull out material one to hold the pump and one to pull material out with pliars
once done before you put back together do a lube on your washer with appliance oil this will insure good maintenance
what i decribed at top is the non costly way to fix your own washer if there is material stuck in water pump
Posted on Jun 13, 2008
Hello fopdycke - Typically when a washer does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage pump or hose may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, timer, faulty pump or control board not communicating correctly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Hello sismurphy1 - Does the washer make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Feb 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Nov 24, 2012 | Crosley Washing Machines
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Apr 30, 2012 | Whirlpool Washing Machines
Dec 25, 2017 | Washing Machines
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Apr 03, 2008 | GE WDSR2080D Top Load Washer
Jan 13, 2008 | GE WBSR3140D Top Load Washer
113 people viewed this question
Ok so my problem was easy! There was one of my sons socks in the line! When I saw people saying they had that problem I thought surely it wasn't my issue and it was! Thank goodness it wasn't anything major! Thanks so much for you help!
