Question about Garden
Kreszow@buckeye-express.comi bought a new ryobi blower/vavuum sept. 1st. chance got to use the vacuum the bag keep's blowing off as the vacuum pull's the leaf's in i can't stop it from blowing off will scrap the entire unit
    President:
  • 1,545 Answers
Don't scrap it, strap it! Strap a nice,strong, long zip- tie on it good and tight and hope for the best!
Posted on Nov 03, 2010
Why is the electrical wire so short
Don't add an extention cord to an extention cord! Buy a 100' 14/4 extension cord and tie the end to the fence so it won't come un plugged.
If the plug keeps popping out of the short cord at the blower,wrap the cord around the handle to prevent disconnection.
Nov 18, 2012 | Ryobi 200mph Leaf Blower & Vacuum Mulcher...
Where can I find a replacement dust bag for my Ryobi RBV-2200 blower vacuum, and what does it cost? I live in Jeffreys Bay.
The part number for just the bag is actually PN: 3410071 or ACC019
http://www.ryobi.com.au/Products/Accessories/LawnGarden/Dustbags/ACC019.aspx
Try these folks
http://www.fastflex.co.za/index.php?page=contact
and here also:
http://www.northlawnmowers.co.za/contact-north-lawnmowers-gauteng.html
This will probably be your best chance of getting the part you need:
http://www.ryobi.co.za/
Contact us today:
Email: ryobi@stevens.co.za
Tel: +27 (11) 357-9600 // Fax: +27 (11) 805-5541
Physical Address: 604, 16th Street,
Randjespark, Midrand, South Africa
I do wish you the best, Thanks for choosing FixYa,
Kelly
Aug 08, 2011 | Garden
How to convert blower to vac. Toro 850 super blower/vac
Remove the air inlet guard on the bottom by pressing the release and pulling down on the guard. It will tilt off. Remove the blower pipe from the front of the machine by pressing the tab and wiggling it off (It is usually a tighter fit than the air guard). Install the vacuum pipe on the air inlet, where the guard was removed. Install the bag where the air blower pipe was removed.
Best regards, --W/D--
Jun 04, 2011 | Toro Garden
Blower works for a while then begins to lose power and eventually turns off and won't turn back on. Has a full tank of same mix I've been using for years. what is the problem?
I'd check the fuel filter in the tank 1st. There is enough line to pull it out and off and you should be able to blow thru it. The I'd check compression which should be 90lbs. or above and if that's OK I'd pull the muffler to make sure it's not clogged up. I'd probably also disassemble the carb & blow air or carb cleaner thru it. Good Luck
Sep 01, 2010 | Ryobi Backpack Blower 25.4cc
It vacums but will not blow
If it vacuums, it is working. The blower tube goes where the bag attaches. Basically, the machine sucks from one end and blows out the other. You just use the end based on your job. Rather than **** leaves in, it pulls in air and where the bag attaches, that's where the high speed air blows out. Hope this helps.
Oct 25, 2009 | Ryobi Garden
Craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
