Question about Jenn-Air JBL800SS Work Top Blender
It works properly only intermittently, as if its moody! When I press the ON button it stays on but when I touch a function button the whole thing clicks off. It seems like a short maybe. Sometimes it'll be okay after a few minutes but other times, most of the time, it won't comply. It is getting power and "kind of " responding to the touch buttons but in a completely unreliable way. PLEASE HELP! This was an expensive blender and only worked properly for a few months. Thanks, Jennifer Klein
Soup maker keeps beeping
I have also had a beeping problem and it was caused by overfilling. I removed some of the liquid and it worked!
Jan 13, 2013 | Cook's Essentials Soup-a-chefs Electric...
I have an ICB 3. The LED display lights up and when you touch the buttons it beeps but, it will not spin.
I called blendtec and got it figured out. The unit was in some locked mode and so I had to push the buttons 4-1-3 in that order to get it to work. The confusing thing is there's two invisible buttons between 1,2 and low, high. So the buttons go 1, 2, 3(invisible), 4(invisible), 5 (low), 6 (high). It mentions these options in the manual on page 18.
Jun 25, 2011 | Blendtec ABC Work Top Blender
When I use the blender it is difficult to get it tight enough on the bottom so that the liquid does not pour out from the bottom. The ring is not cracked. I have had this problem for a long time and it...
Try tightening the ring by (unplugged), align and tighten the base ring, rubber touching glass, then the blade plate assembly, then the ring....Then place on the machine, press down and tighten more...
I find that you cannot sometimes get enough tighening by hand, due to the dimention of the ring and the human hand...
Oct 27, 2010 | Back to Basics Smoothie Elite Work Top...
Maximatic EBL-1000 Elite Cuisine 10... Problem:
Brandy,
-the gasket is a flat rubber ring
-it is used to seal the space between the glass carafe and the plastic carafe base that fits into the base unit
-so the order is glass carafe, chopper blade, gasket, plastic ring...turn this on tightly
-place the whole carafe unit onto the base unit
NOTE: it does not fit firmly...suggest that you hold it firmly before you turn the unit on
so I hope that `fix-ya` works....if not...then ask.
...as any rating than this actually lowers my rank...just the way fix-ya works
bearb
Nov 10, 2008 | Maximatic EBL-1000 Elite Cuisine 10 Speed...
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Juicelady JL600
Call 1-800-233-9054 Found this on the web after searching for an hour looking for the same thing.
Jan 04, 2008 | Juicelady JL600 Professional Work Top...
Jenn-Air JBL800SS Work Top Blender Logo
66 people viewed this question
Top Jenn-Air Blenders Experts
eyecam
Marvin
Marvin
Ross Keen
Are you a Jenn-Air Blender Expert? Answer questions, earn points and help others
