Thanks, i've done it. but....
Thanks for your attention to my problem
but,
nothing happen...
could you give me the next instruction ? please.....
    Scholar:
  • 50 Answers
Noop -
If the drivers from the manufacturer's web site don't work, then I would recommend signing up for Driver Guide, at http://www.driverguide.com
Registration is free, and they have a MASSIVE database of drivers.
Another option would be to install Windows XP instead of Windows 98; Most of the drivers you need should be automatically installed with XP.
Lastly, you can always contact Foxconn Customer Service and request a driver CD. There may be a fee for it, but they shouldn't have any problem sending you copies of the original utilities.
- thinstatic
Posted on Jun 13, 2008
NO SOUND FROM MY COMPUTER
Check the Mute button make sure it is not selected, also check the volume level,move the volume setting higher or to max.
Check the audio chip is OK by plugging headphones into the audio out/headphone socket.
If it is OK then most likely the speakers are faulty and they need to be replaced.
Mar 15, 2013 | Computers & Internet
I cannot create a macro in microsoft word 2010
When you open Word 2010, click on the "View" tab. The "Macros" button will be on the far right. Clicking on the button will allow you to create and edit macros.
May 28, 2012 | Microsoft Word 2010
Is an aprillia rsvr 2001s clutch wet or dry and can i take the side case off with ease
The clutch is wet, and it is fairly easy to access.
Drain oil. If you're not passing the inner cover, it will not be necessary to drain coolant.
Remove rear brake pedal, for easier access.
Now remove the bolts.
If this is not something you've done before,. take it nice and slow.
I would recommend getting a Haynes Manual, which costs next to nothing and gives very clear instructions and advice.
Aug 19, 2011 | 2001 Aprilia RSV Mille R
My iPhone is blocked i can`t see my home screen and the only thing that comes it the Usb showing connect to iTunes and nothing else ,i have tried all the ways to restore but still the same,can give you my...
If you've followed it's instruction to connect it to iTunes and done a sync and nothings still working on it. then it's a problem with the phone. You could try updating the firmware to a newer version and seeing if that helps.
A lot of times, restoring from a previous sync is the harm done. Sometimes, I don't know why. But an old file can corrupt and make things really hard
Aug 16, 2011 | Apple iPhone Smartphone
I am trying to install my new Aluratek external hard drive and after putting in the CD, nothing show up on my computer screen. I am using WIndows XP. Could you please give me some ideas on what I...
Make sure the USB, is connected properly.
I've it is, try switching between USB ports, and see of that helps.
I've it does help, it might be that this particular USB port is dead.
Jun 20, 2011 | Aluratek 3.5" USB2.0 320GB External USB...
I have a N150 plus netbook, 6 mo. old. Using it on the internet this afternoon, it froze up; went to Task Manager, which also froze. I then rebooted and it won't boot--powers up, gives the...
In first remove battery, then one press turn on buttom, then put battery, and turn on.
if will not resaults,
reinstall operating system from CD/DVD
Jun 04, 2011 | Samsung N150 (36725723009) Netbook
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
I have a 2000 Ford Excursion. The fuses for my tail lights, and console lights are blown. Blinkers and brake lights work fine. Does anyone know which fuse numbers I need to give attention to? Thanks.
I ve been tying to write this but had site problems. I am thinking you might have a short in your tow package pigtail .This happens quite often Good luck
Jan 17, 2011 | 2000 Ford Excursion
When I try to play a movie on my Sony S300 player, it will play the previews and then go to the menu as normal. When I hit "Play", it does nothing. The other features on the menu work fine. I can go to...
I had a similar problem and it was fixed by upgrading the firmware to the latest version. Go to the Sony site and it will give you full instructions on how to do this.
Apr 10, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Remote codes for RCA Digital TV Converter Box (DTA800B1)
I was just looking for them and then found my manual and felt bad for you guys so I scanned it and uploaded it to photobucket ^^ please feel free to save the remote codes but you may have to zoom in alot to see them ^^
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan007December152008.jpg
http://i37.photobucket.com/albums/e83/Megumi_Kurama/Scan006December152008.jpg
Sep 16, 2008 | Televison & Video
Computers & Internet Logo
301 people viewed this question
David Payne
David Payne
