Question about Samsung CLX 3160fn All-In-One Printer
My CLX-3160FN printer will no longer print. It says to replace imaging unit soon (up until it stopped printing it was working fine, no problems on scans, copies, faxes, prints) but only recently it stopped feeding paper. It says "Memory Received" so I know there are faxes waiting to print... but it just simply won't do anything. I turn it off, and back on. Nothing. It will revv up, say "Printing..." but then stop. Thoughts?
    President:
  • 670 Answers
You will need to replace the imaging unit. It the part where the toner cartridges and waste toner tank sits. The part number is CLP-R300A. You can find it online or at your local office supply store.
Posted on Nov 05, 2010
Samsung CLX-3160FN problem with faded black images/text only
Many of today's printers have a "toner save" option, which makes the black appear lighter, and I'm pretty sure this isn't your problem. However, I wanted to rule-out the obvious first, which is just a setting.
If you're seeing the black lighter in vertical "stripes" or segments in your printing, then it's most likely due to a dirty toner cartridge (but you said you replaced it), or cleaning the LSU inside the unit (as it says in the owners manual).
Just in case you don't have the manual handy, here's an online link to it:http://downloadcenter.samsung.com/content/UM/200611/20061122152910875_CLX-3160_English.pdf
I hope this helps!
Feb 13, 2012 | Samsung CLX 3160fn All-In-One Printer
When printing, there is a band, right in the center of the print, that is very faded. Do I need to replace the imaging unit?
If your printer is printing with faded vertical banding like this.
slamfix_28.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Jan 21, 2011 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
When printing the colors print fine, but both the new and old black cartridge produce light, streaked and mottled print.
Your problem is in the black developer (where the toner go inside the unit), I assume that you use compatible tone?! That the most common problem, you most likely will need to replace the imaging unit, as the black developer is part of it. You also can run an original toner and see if the problem will go away, I doubt it.
Dec 02, 2010 | Samsung CLX 3160fn All-In-One Printer
I get faded black printing on the same areas. I tried printing in color and it works fine, fading goes away. It only does it on black. I tried buying a new toner and same problem
Nov 01, 2010 | Samsung CLX 3160fn All-In-One Printer
My pages are printing correctly on the edges but light in the middle on my clx 3160fn. it has a new black ink cartridge
Is it only with one colour ? I had the same problem (only with black) and before buying another unit dismantled the imaging unit to find a build up of toner on the metering plate edge, I cleaned it and now it's fine.
It takes a bit to get to... 3 fixing screws each side plus one for the belt shute and one at the top. Remove the side plates, followed by the image drum (with great care) then each colour toner roller unit (they just slide forward) until the black unit is exposed. Remove the 5 cover fixings and then you can clean the plate edge. kh
Jul 11, 2009 | Samsung CLX 3160fn All-In-One Printer
Imaging Unit needs to be Replaced
No, what actually happens is the drum fills up with waste toner and you cannot empty it.
Jan 09, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Jan 04, 2008 | Samsung CLX 3160fn All-In-One Printer
My printer is not printing
My printer at work kept saying it was low on black toner. I finally replaced when I got the message Black toner supply error. I gave it a minute or two to adjust itself and when that didn't work, I turned off for about ten seconds and then restarted it. I've only had two problems with this printer and I have had to turn it off both times before it would work perfectly, if that helps anyone.
Nov 05, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
430 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
