Question about Jl Audio 500/1 Car Audio Amplifier
Jl audio 500/1 amp
Recently hooked up amp to a jl15w3 had it hitting for about a min or two then all of a sudden it stopped hitting the amp stayed on then two min later everything turned off my amp and my capacitor tried hooking it again and the amp power light turns on when u hook up just the power and negative to amp then power light turns off after a min but when u hook up the remote and turn the stereo on the amp doesnt turn on
  • 631 Answers
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Posted on Jun 14, 2008
Have a jl audio 500/1 the red light blinks and no other light turns on. whats the problem with it?
I think you might have your remote turn on from your deck to amp hooked up wrong check that out!! I not are you familliar with the mr. butterworth crossover JL developed for that series of amp? Just like its big nrother the 1000x1 class D the built in smart crossover has many built in pretect modes. If your subs are drawing to much power it shuts down if they draw to little of ohms or to many but that 500 is 1 ohm stable so download the crossover settings from JL and go from there
Apr 28, 2012 | Jl Audio 500/1 Car Audio Amplifier
I have a jl 500/1 amp hooked up in my car and the power light comes on for about 5 seconds then turns off. no sound out of the subs. it is hooked up to a factory deck through a high to low level converter....
hook up the remote wire ( or make sure its hooked up good) check your ground! ground wire not big enough awg wire and put on bare metal not more than 1 foot away from amp. bad ground will cause this.
Sep 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
If the amp is a JL 500/1v2, it has a sensing switch which enables it to sense voltage, instead of running a remote wire. If this switch is set to on, and you have a remote turn on wire running to the amp........this can happen. I own one of these, and made that mistake myself.
Oct 18, 2010 | Jl Audio 500/1 Car Audio Amplifier
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 500/1 problem
Usually all amps spark a little when hooked up again after a while of no use. this happen cause there are many little capacitors inside to keep the amp running when hitting long bass notes. I think the reason you have been having problem after replacing the transistors is because there not the rite model number or maybe the polarity. You mite have to call jl and ask them if they have any in stock or google the model number of the transistor and buy them and replace them and see if it work. if it doesnt work then it mite be something else inside.
Jan 16, 2009 | Jl Audio 500/1 Car Audio Amplifier
There are no fuses inside the amp.
Are any of the lights lighting up on the amp?
If so, which ones?
Jun 09, 2008 | Jl Audio 500/1 Car Audio Amplifier
Low ohm light on my jl 500/1
If the low impedance light is on, the amp probably has shorted output transistors. If you don't know of a good local repair shop, call 'several' of the local audio sales/installation shops to see who they use. If more than one audio shop recommends the same repair shop, they probably do good work.
May 08, 2008 | Jl Audio 500/1 Car Audio Amplifier
500/1 and 300/4 jl
Need more info here. did you run power from the 500/1 to the 300/4, or did you run the signal from the 500/1 to the 300/4? Also which amplifier is cutting out for a min...the 500/1, the 300/4, or both? each amp should be wired to a distribution block with 4 awg power wire recommended for each. the amps should also be wired without any capacitor.
Mar 17, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
226 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
