Question about Dell Inspiron 6400 Notebook
My dell laptop still freeze
My computer is slow and after using it for half an hour, it freezes (the mouse wll no longer control the cousor) and all applicatio on it will cease to work until i swithch it off from the power burton
  • 191 Answers
If its windows XP try doing a MSCONFIG:-
my dell laptop  still freeze - startup_tab_xp.gif Here's a good example. On my computer I have a mess of MP3s and I listen to those MP3s with a program called WinAmp. For some reason or other, WinAmp decided that it should always be running on my computer even when I am not using the program. That's silly. To prevent WinAmp from automatically starting every time I boot my computer, I ran MSCONFIG and unchecked "WinampAgent." That's it.
Remember, disable only those programs that you recognize and don't need to have running all the time. When in doubt, leave it on.
5. Click on the OK button.
6. A message will pop up telling you that you must restart your computer before these changes will take effect. Click on "Yes" and your computer will automatically reboot.
restart_box_xp.gif 7. That's it! Your computer should now boot faster and crash less.
And if you ever want to turn on any of the startup items you disabled with MSCONFIG, just run MSCONFIG again.
when your system restarts you will get a prompt that you have used systemconfiguration utility
do remember you put a chkmark in the box which says do not show me this message in future and then click ok.
Posted on Jun 16, 2008
  • Rahil Kamra
    Rahil Kamra Jun 16, 2008
    1. In Windows XP, go to Start > Run
    Run in Windows XP" src="http://www.netsquirrel.com/assets/start_run_xp.gif" width="285" />
    2. Type MSCONFIG in the "Open:" box and then either press enter on your keyboard or click on the OK button.
    3. This launches Microsoft's System Configuration Utility. Click on the Startup tab (the tab at the far right).
    4. This takes you to a page with a list of "startup items." Startup items are programs that are automatically loaded every time you turn on your computer. Some startup programs are absolutely necessary, others are simply a waste of RAM.
    In Windows XP, all of Windows' essential programs are loaded through something called "Windows Services." This means that most of the startup items you see in XP are completely optional and can be turned off. However, a good rule of thumb is to disable only those programs that you recognize and don't need to have running all the time. When in doubt, leave it on. Or, better still, check out Paul "PacMan" Collins' huge "Startup Applications" list at http://www.sysinfo.org/startuplist.php. This list of over 13,000 startup items you may encounter in MSCONFIG tells you which items are absolutely necessary, which items are optional, and which items you should definitely uncheck.
  • Rahil Kamra
    Genius:
  • 2,028 Answers
It could be as simple as two conflicting programs. Go in and remove programs that you don't use, and get rid of any multiple programs that you don't need, such as multiple tool bars, anti virus, spy ware, etc.. If this doesn't cure it, then it may be a hardware problem. A very common cause for this is a memory chip going out. However it could also be the fan not working properly and the machine is getting hot. Rarely, but not unheard of, is the processor going out.
Frozen screen when hot
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Most of the time, PC starts running slow and freezing by lots of reasons. Corrupt registry, unnecessary applications, as well as too many start-up items would be the major reasons contributing to this problem. Many PC users simply utilize PC yet never consider how to maintain and optimize PC performance. I would suggest you to download any reliable program to fix registry, to manage unnecessary applications & start-up items like am using Reginout since 2011. Many programs are available in market which can perform these steps, but don't believe on free products. Now its up to you. :-)
Good Luck.
Nov 12, 2013 | Dell Latitude E6510 Laptop
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Why does my pc run so slow?
Hello
OK, the link below should explain to you some of the factor which contributes to a PC running slow.
Click HERE.
Kind regards
Andrea
Aug 31, 2010 | Dell Inspiron 1720 PC Notebook
Mouse freezon
Turn your computer, wait until your antivirus is made first full scan (during of this your computer maibe will run slow). After this your computer will work like before renewing Karspersky.
Mar 02, 2010 | Dell U0636 Mouse
Dell d600 freezes intermittantly
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Jan 11, 2010 | Dell Latitude D600 Notebook
My dell inspiron e1705 will power on for tenmin beeps then freeze
Sounds like it's a motherboard or processor issue. Why, well when you said it's slow and freezes, sounds like either the motherboard or processor (I've had this issue with both) and as a long shot it could be a hard drive dieing.. (stops spinning intermittently)
Dec 23, 2009 | Dell Inspiron E1705 Notebook
Mouse quits
go onto the support page for the pc you have. ex: if you have dell go to www.dell.com then go to the support section. from there look for mouse/touchpad drivers and update the drivers. that should fix the problem. if the problem continues or if you have no other pc to use insert the operating system cd and re-install the operating system. of course make sure you back up your files first. thank you for using fixya.
May 04, 2009 | Computers & Internet
Mouse freezes when i move it on desktop or a window.
hi, ok go into control panel,printers and other hardware-mouse -slow the pointer speed a notch at a time. this should help. good luck,glen
Jan 04, 2009 | Microsoft Wireless Optical Mouse
Laptop 'freezes' after about half an hour of operation
Is the hard drive making a clacking noise, and/or does the mouse freeze only once or freeze and unfreeze a few times before dying completely?
Nov 21, 2007 | Computers & Internet
My mouse freezes up
have you tried new batteries?
Sep 15, 2007 | Dell U0636 Mouse
Dell Inspiron 6400 Notebook Logo
389 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
