Question about Maxtor Hard Drive
My maxtor external hardrive contains all our photos and suddenly my computer can't recognise it. help!
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
EXTERNAL MAXTOR HARDRIVE WAS ISLIGHTLY DROPPED. NOW WHEN CONNECTED TO COMPUTER (USB) DOUES NOT DECTECTED. POWER ONLY FLASSHED (LED), AND MAKE A SMALL CLICK HARDRIVE SOUND, LIKE IT IS TRYING TO SPIN OR READ...
I think that your disk-drive is "SLIGHTLY" dead. :-(
Disassemble the enclosure.
Get the model-number and serial-number from the label on the disk-drive.
Access Maxtor's web-site, and check the warranty-status of the disk.
If the warranty still is valid, Maxtor will replace the disk-drive, at minimal cost to you.
If the warranty has ended, buy a new, compatible, disk-drive, and install it into the enclosure, to "reconstitute" your external storage-device.
Oct 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Hi My Maxtor External Hardrive is connected to my laptop the green light is on but its not recognised by the laptop.
Welcome to fixya,
The main caused of the problem is the enclosure of your Maxtor ext drive you need to change ot replace it to a new one. Take your hadridsk out of the enclosure and buy new enclosure and then put your hardisk back on to the new enclosure.
Aug 13, 2010 | Maxtor BASICS Personal Storage 3200...
Maxtor 3100 80GB External Hardrive clicking/humming sound.
This could be an issue with the circuit board.I am facing a similar problem & shown it for repairing. And facing issue in sourcing the IC. Seagate is giving support for maxtor after it has taken over. Data recovery is possible only if the circuit is working.
Jan 10, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
I have a Maxtor 80GB external hardrive and I can't get into it. I have checked all the plug connections, shut the computer off and rebooted. The short cut to my photos on my desktop has also disapeared and...
Flashing light shows that your pc is comunicating with the drive, so it is posible that it is damaged, is the disc ide or sata, try conecitg it directley on the motherboard like a slave disc.
Sep 01, 2009 | Maxtor Computers & Internet
Need to dump my data from my mac to my maxtor external hardrive
you need to backup your system using windows back utility on your computer and save the files to your external hard drive.
Good Luck
Jan 19, 2009 | Maxtor Hard Drive
Maxtor hardrive installs but gets recognised as a localdisk
mi pm4 no puede ser leido en una computadora y no se puede prender
Oct 29, 2008 | Computers & Internet
Hardrive not recognised my computer yet the power light is on
go to control panel.. go to Administrative tools.. then .. go to computer management.. on the left pane.. click disk management.. u can detect all ur drives in here including those who are not seen by your MY COMPUTER..
Apr 13, 2008 | Computers & Internet
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
New Maxtor 3200
Hi, This is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the PS3200 itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
51 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phillip Whisenant
Phillip Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
