FixYa.com
Tags:
Ultra Linear UL-2200D Car Audio Amplifier
Amp Turns of when i put the volume up to 20
posted by klucks on Jun 13, 2008
well like the subject says my amp turs off when i put up my volume and its wired up good...the amp is a US Amps MD-1
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 15, 2008
Not Rated (0)
creplogle
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
if it only happens when you turn it up, you could be sending it too hot of a signal and its clipping so the amp is protecting it self and shutting off. Try lowering the input gain on the amp and see if that helps. It's also possible that your speakers are pulling to much power when you have it turned up that high and the amp is shutting down to keep from overheating. I don't know what or how many speakers you have hooked up, but if you have a sub, try it without that and see if you have the same problem. If you don't have a sub, disconnect the largest woofers you have. Different speakers have different ratings for how efficient they are. It's usually measured by how much SPL 1W will produce. You want to disconnect the speakers that are pulling the most power and try it again. If your speaker is pulling more power than your amp can supply, your amp could shut off because of that. As well as cook the voice coils in the speaker and damage the amp. It's always better to have too much power in your amp than not enough. There's an old joke I learned in audio engineering school "I can pass a square wave.....once."
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Car Amplifiers problems?
Car Amplifiers
genon avr1601
Hi gud day i have genov avr1601... Answer This...
Car Amplifiers
i need a code for a universal...
code for a remote control... Answer This...
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
Car Amplifiers
code for kenwood cd player
I just bought this car... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
