Question about Olympus Stylus 710 Digital Camera
How to fix my camera
My camera wasnt removed from the computer properly, it wont start anymore.. the lens wont open..
My camera is a kodak 7.0 and one day i was charging it through the computer and when it was done i turned it on and the whole scenn was purple it was always like that and when it isnt purple theres stipes all through out the pic i dont know what to do
Posted on Jul 02, 2008
Camera wont turn on anymore. it says "Lens error,
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Jan 03, 2011 | Canon PowerShot A1100 IS Digital Camera
My camera is saying lens error and it wont open the lens
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Aug 12, 2010 | Nikon COOLPIX S230 Digital Camera
Lens error, lens do not open
Jul 14, 2010 | Canon PowerShot A1100 IS Digital Camera
Just says lens error and wont stop making grinding noise
Jun 16, 2010 | GE A730 Digital Camera
Lens error lens wont close what to do?
Hi,The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Here are different solutions to this problem;
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Thanks and take care
Apr 25, 2010 | Nikon COOLPIX L18 Digital Camera
My fijifilm a345 will turn on but the lens wont open anymore
Read the second comment in my tips n tricks for this problem.
"THE ONLY WAY I KNOW HOW". I also have photo's to help
Sep 13, 2009 | Fuji FinePix A345 Digital Camera
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
Lens error, lens wont come out at all just started wasnt dropped hit or anything
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 27, 2009 | Sanyo Vpc-s1070w Digital Camera
The focus lens was hit by a basketball and it won't take pics.
Have you tried a different lens on the camera almost any lens with the same mm size will work. If it still does not take pictures with another lens. You should take it in for service.
Dec 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
Olympus Stylus 710 Digital Camera Logo
115 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
