Question about RCA 32F530T 32" TV
Dead T.V. RCA 32" T.V. was working fine then just died, no power, no picture, no nothing. What possibilities am I looking at here?
    Master:
  • 497 Answers
Iv come across that this model wasnt successful..try taking this tv back to the dealer..if nothingwrks..then its time u buy another one..srry
have a nice day!
tc
Posted on Jun 13, 2008
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
No picture
Its certainly possible there may be something wrong with the port itself but first, I would try swapping out the hdmi cable itself to rule that out. It may also be the video board in the receiver. Can you get video out by using RCA cables instead of HDMI? Maybe try that first.
Jul 27, 2012 | Insignia - 450W 5.1-Ch. A/V Home Theater...
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
I was wondering if I could get some help with a RCA F22715 32" TV, please. Was working fine, then got up one morning and tried to power on. No green light on top of set, remote wouldn't power it up. Power...
I would check the (hot) or horzional out put transistor. Its possibly shorted. Also check the power supply for any other secondary fuses. They may look like a resistor, but they could be identifed on the pcb. Look at all the capacitors in the power supply to see if any are bulging on the top or leaking at the bottom. Alway replace any compoenent with the same value. Hope this is helpful.
Nov 26, 2009 | RCA F32715 32" TV
My protron 32" lcd tv was playing and just died no power. I tried unplugging the tv to reset and nothing happen
Your power supply is dead. You can get one from POWER-ON.COM for about $64.00 including shipping and handling. My 32 inch went dead after only one year and I just got a new power supply and it works fine.
Nov 05, 2009 | Protron PLTV-32 Television
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA 32V550T Nothing happens when you press Power. NOTHING.
This set needs a flyback transformer p/n 262342, and a horizontal output IC, location number on the board is q14401 and crosses to NTE2353. When you're in there too touch up any bad solder joints you can find. Fixed several of these with the same problem.
May 25, 2009 | RCA 32V550T 32" TV
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
RCA 32" 1996 COLOR TRAC PLUS
Hello neall,
It sounds like you may have a power supply problem- (HV Power supply). I must ask if you have sound or not? If you have sound it is the HV supply only if you do not have sound the Low Volt power supply and possibly the HV power supply/Horizontal section has a problem. I would suggest that you take the TV to a qualified TV repair shop.
I hope this helps,
Thank You,
Shuttle83
Mar 18, 2008 | RCA F32632SB 32" TV
Open Questions:
RCA 32F530T 32" TV Logo
145 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
