Need tv code and direct tv code for universal remote
I have a sharper image jumbo universal remote and i cant seem to find the instructions to program my tv and direct tv can u help me with the codes so i could use the remote instead of 2 or three.
  • Anonymous Oct 24, 2008
    i need codes
Um no Jk. what you need to do is hit code search, and aim it at the device you want to program, hold code search untill it blinks and then press the icon of the deviced being programed on the remote.
Posted on Aug 04, 2008
I need to program my jumbo universal remote the sharper image but can't find the instructions needed to use the proper code for a vizio 19 inc.tv
Hey neri melendez!
You can find instructions on how to program our remotes at this link: http://www.dishnetwork.com/SupportSection/remote-setup. Select your model of receive from the list and the PDF document will contain the instructions on how to program your remote in the future. I have provided the steps below for quick reference for you!
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Let me know if you have any other questions!
Tommy Faust
DISH Internet Response Team
Nov 24, 2011 | Vizio Televison & Video
The sharper image jumbo universal remote jvc tv
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
Jan 04, 2010 | Televison & Video
Programming
i need codes to jumbo sharper image universal remote
Jan 27, 2009 | One For All URC-9910 LCD Remote Control
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual.
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
..check it out....
http://www.blurtit.com/q717681.html
Feb 17, 2008 | Televison & Video
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Feb 09, 2008 | Televison & Video
Sharper Image Jumbo Universal Remote
i just pirchased a Sharper Image Jumbo universal Remote but i can't find a code for the Pioneer DVR 541H is DVD recorder. Does anyone have this code or  a suggestion?
Jan 10, 2008 | Televison & Video
Jumbo Universal TV Remote (Sharper Image-Innovage)
sharper image jumbo remote can't get it to program my philips/magnavox tv.
Dec 25, 2007 | One For All URC-9910 LCD Remote Control
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
Electro Med Services...
