What are the ip numbers - Computers & Internet
Need to know wat ip number is and port is
IP stands for Internet protocol.
It's represented by numerical code, which is assigned to each device like computer, printer, phone.
IP's are two types. There are Internal IP, External IP
Internal IP means that your system ip address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system ip address
External IP address means that your network IP address. If you want to know your Network IP address then visit IP-Details.com here it display IP address, ISP,location, Longitude, latitude and so on.
To find your port number follow these commands:
Go to start--->cmd---->type netstat -a
Feb 02, 2014 | Televison & Video
How to convert local ip camera addresses to ip addresses to connect from internet
depend on what brand and type of the ip camera that you use.
in order to be able to access from internet:
- you need to use a router that connect to a switch and the camera
- the router must have UPnP Feature & Port forwarding.
- just in case your public ip address is dynamic, you will also need a ddns for redirection.
The basic concept is, you have to configure the network setting of the camera according to the router as a gateway.
usually, in the network setting, you will find a http port number.
change this number from default ( 80 ) to another number from 0 to 65535 ( example 50010 or 40000 , you can choose freely, it's recommended to use port above 50000 )
then find the portforwarding function in your router, then set the port number to the ip address of the ip camera.
if it's successfull, you can directly access the camera from the internet by entering your public ip address and the port number on your browser.
for example : http://itcomm-streets.viewnetcam.com:50001 << my ip camera demo unit.
Jul 02, 2012 | Android Apps
How can i change the ip and default gateway of barcode printer Toshiba B-sx4?
I hope thisis understandable.
  1. Switch printer off
  2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
  3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
  4. Press [PAUSE]
  5. Press [PAUSE]. Display shows IP Address
  6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
  7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
  8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
  9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
  10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
  11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
  12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
  13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
  14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
Dec 11, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
How to configure internal LAN in B-SX4T barcode printer?
  4. Press [PAUSE]
May 05, 2010 | Toshiba TEC B SX4T Printer
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
What is a ip address
Its address of the computer, in order to address of the computer make use of this site http://www.ip-details.com/ip-search/
i used this site for finding Ip address ..
it provides information at free cost ..
Jun 03, 2008 | Video Game Consoles & Games
IP ADDRESS
I need to know a little bit of information. Could you please go to start>run>cmd. In the command prompt type "ipconfig /all" without the quotation marks. Please let me know the information displayed.
May 09, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
What is an ip?
IP= Internet protocol it would have numbers like 192.10.10.10 or what ever range the isp uses. If the first 3 numbers have a 169. whatever you are not connected.
Apr 22, 2008 | Apple iMac M6709LL/B Desktop
Haloo
No. Just leave out the 'leading zero's' in the ip address. for example: if your ip is .... 10.001.06.11 type in only 10.1.6.11
Aug 21, 2007 | Ricoh Aficio 450 Copier
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
