Question about ASUS K8V-MX Motherboard
Does asus k8vmx motherboard support sata hard drive?
  • 73 Answers
Yes it can support
Posted on Nov 03, 2010
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
I have an asus motherboard. I bought a 1T sata hard drive. does this motherboard PTN-D support it
Hello
sata is the standard now,so your motherboard should support your drive.
Your part# does not match any asus numbers,im giving you a link to asus.
If this is an older mother board it may not support sata.Also you will see sata connections on the motherboard.
If you do not then its not supported.
http://usa.asus.com/ProductGroup2.aspx?PG_ID=mKyCKlQ4oSEtSu5m
Apr 12, 2010 | ASUS Computers & Internet
Asus K8VMX board didnot detect SATA hard disk
Sounds like you just need to install your SATA drivers. Look around for your cd/floppy disc of drivers if you have any. When you boot from the CD, It will ask you if you have any other drivers you would like to install, thats when you install them and it should read your SATA hard drive just fine. If you dont have your driver CD anymore search ASUS's website or just google (or similar search engine) your motherboard and look for drivers. Beware of some phony sites though. Good luck :)
Jun 17, 2009 | ASUS K8V-MX Motherboard
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Asus k8vmx vista drivers
If U R Using Vista Then ::
Go to Device Manager Then Update Driver From Internet Connection Then All Drivers U can Upgrade Using This
Apr 29, 2009 | ASUS K8V-MX Motherboard
Sata hard disk drive on asus p4v8x-x motherboard
I have checked and you computer does use SATA drives. If you don't have a manual, send me your email and I will forward the manual @ no cost. The manual will show you where to insert the cables.
Jan 20, 2009 | Computers & Internet
Hi, thanks, need more help
hi
i have problum with windows mother board not be installed a window xp in k8vmx
Oct 04, 2008 | ASUS K8V-MX Motherboard
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
ASUS K8V-MX Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
