Question about Sharp Office Equipment & Supplies
Noise from drive at top right back of mach. - Sharp Office Equipment & Supplies
  • 71 Answers
Hello Dear, you need to specify clearly which printer you are using, if its a laser printer probably the Fixing Film Unit is torn off, you need to get it replaced.
Warm Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 13, 2008
How do I download a movie to my mp3 eclipse
you will need to connect your mach speed eclipse to your computer once connected you should be to see it if you cant see it you might need to install it click start control panel administration tools computer management divice manager scroll through all of your devices if you see a yellow quetion or exclamation mark or a red X you will need to install drivers for this device right click select update/reinstall drivers if your computer came with a motherboard disk the drivers could be on it
when your movie starts to download a browse option should open you can select your mach speed eclipse drive or once its downloaded you could copy and paste the music into the flash drive or drag and drop it into the speed eclipse drive
click start all programs accessories open windows explorer navigate to your movie files right click on the movie right copy navigate back to the destination drive right click select paste or hold the mouse cursor on the movie files drag them to folder
then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another
device floppy or a usb device
hope this helps
Aug 14, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore washer elite top load
sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Sep 21, 2008 | Kenmore 24032\24036 Top Load Washer
Humming noise
if you're talking about during fill probably just a noisy valve may or may not be a real concern just a noise if objectionable replace valve
Sep 01, 2008 | Roper RAS8445KQ Top Load Washer
Noise when the typewriter is conected
two different machines and problems.
on the sears mach. need more info. make sure mach. is turned off when you plug it in. does it still make a noise? does it make the noise when you turn the mach. on? what kind of noise. does it still work?
on the olivetti, check the ribbon. if it is at the end, the mach. may not work. replace ribbon. check to make sure printwheel is latched into place and the cover is down. if it still doesn't work it may need a new main board.
Jun 23, 2008 | Office Equipment & Supplies
HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
May 17, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Kenmore washing maching 25862
yes you need to replace the motor coupling between the motor and transmission let me know how you make out
Dec 21, 2006 | Kenmore 25862 Top Load Washer
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
