Question about Asrock K7VT2 Motherboard
Beebing tree times
My mother board beeb three time and start agan untill i switch off the pc
i chacked the ram and it working alright
    Scholar:
  • 50 Answers
Louise -
Although the memory may be working okay in another system, the three beeps at post still indicates a memory(RAM) problem. Your motherboard uses AMI BIOS, as indicated by the product specifications on the Asrock website; In the post-error code listing, three beeps is a memory issue.
Check and make sure you have compatible memory for the motherboard; and if possible, test with new or alternate memory sticks.
If new memory doesn't resolve the issue, I would say the RAM slot(s) is damaged, which would require totally replacing the motherboard.
Hope this helps!
-thinstatic
Posted on Jun 13, 2008
When i switch on my lenovo m58 desktop i get a beeb sound then the fan starts being loud then it automatically switches of then the loud sound from the fan continues....i've tried to remove the ram and the...
This is short false-alert of the time gap during start-up, and it happens on Intel based boards. Just take care of fan controls in BIOS, and try to locate missplaced fan connectors viewing the board layout. I know the lunatic who plugged a processor fan into system fan connector, and everything works fine, but monitoring is too bad, got it?
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Mar 18, 2014 | Lenovo ThinkCentre M58e 7298 Core Duo...
My GA-VM900M Mother board gives a long beep after another when I switch it on. The monitor remains black and the power light stays on.
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2581#dl
Drivers or the manual can be selected in download type.
A long beeb is a fault in a RAM module.
Try to insert a ram module you know is working.
Your mainboard use DDR 2 ram, up to 4 GB.
Another fault could be the power supply.
Blow also any dust out with compressed air before working on the mainboard and take antistatic precautions
Here is a list of beeb codes:
http://www.computerhope.com/beep.htm
Good luck
Jan 04, 2013 | Computers & Internet
Some times randomly the screen will go black and say no signal detected then it will give off a beeb then three beebs then 3 agian i belieave whats this problem? and is it fixable or is it with the board
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps
Sep 01, 2011 | Computers & Internet
I have a open desktop pc it is not work and there is no eny beeb
Unplug ur USB wires from ur mobo & try. Have u tried to reseat ur graphic card as well?
Feb 06, 2010 | AOpen MX34 (91.88510.101) Motherboard
2007 dodge ram 4.4 beeps when i press the brake pedal but the tail light is out on the left side also. And when you turn on the left blinker it goes crazy fast and no light in the light assembly. Help?
If you have a beebing noise every time you press on the brake, it is because a tail light is burnt out. There are two filaments in each brake light. Therefore, when you turn on your hazards, it will appear that both tail lights work properly. The beebing warning sound is actually a feature that Dodge put in the Rams so drivers would know their tale light is out. Just replace the tail light bulb, and the beebing will automatically cease. To get the tail light housing out, you will need a torex screw driver. Also, you twist the bulb housing out as opposed to pulling it out. There are three prongs that twist out.
Jan 21, 2010 | 2007 Dodge Ram Truck
I have intel845 board when i switch on power without ram i get ram beeb but if ram installed i cant get any beeb & no display & board star power on automatically
If the board is starting properly with RAM installed but you are getting no display then the problem is with the video card or onboard video. If it is onboard video then you should be able to fix this by purchasing a compatible video card and installing in your pci-x slot. Make sure you disable onboard video once you are able to get into your bios. Hope this helps.
Sep 13, 2009 | Computers & Internet
My monitor is working but nothing shows up. when I turn computer on I here three beebs a 10 sec pause three more beebs and so on whats the problem. motherboard is a ECS P4VMM2 V5.X that I rehooked up
The 3 beep error code means there is a prolem with the RAM, it could be faulty or needs reseating.
Try reseating the RAM and if this doesn't work then if you have more than one RAM module insert one at a time to determine which is the faulty RAM module.
OR take the RAM modules to your friendly computer shop to test them for you.
Aug 24, 2009 | Computers & Internet
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
Asrock K7VT2 Motherboard Logo
171 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
