Question about Pioneer DVR-107D DVD±RW Burner
I can't write DVD with my Pioneer DVR-107D DVD±RW
Hello.
I need your help.
I bought a SONY VAIO VGN-FZ290EGS notebook.
The type of DVD/CD-ROM is PIONEER DVD-RW DVR-K17 ATA.
I can read, but I can't write CD/DVD.
When I am trying to write some data with NERO , I don't know why, but burning speed is only 2x ( is it not strange???? because DVD+R Write is 8x max, and for DVD+R is 1x to 16x).
However, the process of burning goes normally, and in the end Nero says that the process was finished successfully.
After that, I take DVD and again put it in DVD ROM. The DVD was spoiled. And the computer doesn't recognize the DVD.
I don't know what to do.
Please help me.
Regards, Samvel
  • samvelc Jun 13, 2008
    Hi worldvet,
    Thanks for your response.
    I used FujiFilm DVD+R 16x blank media.
    I already tried the Nero's option "verify" but it doesn't helped.
    Thanks,
    Samvelc
  • samvelc Jun 14, 2008
    Hi Worldvet.
    Thanks a lot for your response.
    I'm using Nero Ultra 8.1.1.0.
    Nero burning temp file location is "C:\Users\Samvel\AppData\Local\Temp\"
    I would like to note the following:
    a. today the same version of Nero I installed to a Notebooks of my friends (HP and Toshiba, the first one is VISTA, and the second one - Windows XP) . I burned DVD on there computers with my FujiFilm DVDs. No any issue.
    b.I also tried to write a DVD with Roxio Easy Media Creator 10. But I got the same issue.
    I don't understand, is it hardware or software issue.
    It seems, that is a driver problem.
    Samvel
Download install and run Imgburn_2.4.1.0 as a TEST.
My Drive did not work with Nero 7 but was fine with the latter.
This proves Nero can be quirky with some drives.
Posted on Jul 14, 2008
    Guru:
  • 859 Answers
What brand of media are you using?
You are burning at 2x because that is the highest that this drive supports.
You would also want to instruct Nero to Verify by ticking the check box and either finalize disc or make it mulitsession, if your burner supports multisession DVDs
Regards,
Worldvet
Posted on Jun 13, 2008
  • Glenn Rogers
    Glenn Rogers Jun 13, 2008
    This is going to be a series of question responses between us to get to the bottom of the problem. Its the trouble with troubleshooting via email responses. If I were in your home at your computer we could get this done in less than an hour.
    So please don't rate this, until I give you a final verdict and or we succeed. It is possible you have a bad burner, but we have to rule a lot out before you can request a replacement and be knowledgeable in your request as to why.
    Have you used Power Burn in the Nero burn settings?
    Where have you set the Nero burning temp file location in the setup pages of Nero?
    Which version of Nero are you using? Drop the help menu down and select About
    Have you downloaded and applied any Nero released patches yet?
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 14, 2008
    I run into this sort of thing all the time. I'll get back to you soon.
    WV
Pioneer dvd-rw dvr-k17 problem
dera ingrid 61
Please reinstall the drivers for the both of the problems,if you dont have any cd then plz visit the manufacture website and download the drivers, after installing the problem is not solved then plz try with another drive,if the problem persist then try by reinstalling the OS
Apr 25, 2008 | Pioneer DVR-107D DVD±RW Burner
I have a sony vgn cr220e that comes with a pioneer dvd-rw dvr-k17 ata optical drive and had original vista home premium OS, but someone fomat hdd and installed windows 7, now i am having problem reading...
You should have a start up disc for the thing that will restart the drivers or go the the Pioneer website and they posslbly have an upgrade or even on the microsoft website just look if not reformat the hrddrive with the original os if it wasnt bootlegged
Jan 18, 2010 | Pioneer DVR-107D DVD±RW Burner
Using pioneer dvd-rw dvr-107d and it won't read dvd's. Need a solution.
Most common cause of this is a dirty lens. Try cleaning with a good quality dvd cleaner. This should fix the problem. Hope this helps.
Oct 13, 2009 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-K16D driver?
www.findmysoft.com/drivers/Vaio-VGN-BX394VP-Pioneer-DVR-K16-Update-1-10-firmware-driver.html , free download your driver cd in the above website
Jul 25, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
I also lost my DVD drive, in my sony vaio VGN-FG58e laptop. It also have Pioneeer DVD-RW DVR-K_17 ATA and the error code is 39. Could you please suggest the solution.
To solve this follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording application
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7)uninstall the drivers for cd drive and dvd drive from device manager and then
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that there is no yellow exclamation on the CD or DVD drive
Jun 14, 2009 | Pioneer DVR-107D DVD±RW Burner
CD DRIVE - NOT RECOGNIZED
If you are having a problem with one particular cd.... examine it for scratches or smudges.
Robert
Sep 05, 2008 | Pioneer DVR-107D DVD±RW Burner
This worked: thanks to riozebratubo
delete the entires in regedit.exe
"UpperFilters"
"LowerFilters"
They're inside:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
-uninstall the driver
- restart
Vista is searching for existing drivers -> done
Feb 05, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVR-107D DVD±RW Burner Logo
331 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
