Question about Maytag Washing Machines
My washer wont spin out
My washer wont spin. It makes a buzzing sound but wont spin out.
    Genius:
  • 1,224 Answers
Kinked hose or blockage in the water pump you defininatley have material in the water pump
disconnect washer all together pull out after you drain the water by hand as far as can go use a dolly take out side drain the rest by tipping on side you might need 2 or 3 people to get the washer out with little water left when on side pull the water pump off look inside and pull material out with a pair of needle nose pliars that clamp you will need 2 people to pull out material one to hold the pump and one to pull material out with pliars
once done before you put back together do a lube on your washer with appliance oil this will insure good maintenance
what i decribed at top is the non costly way to fix your own washer if there is material stuck in water pump
Posted on Jun 13, 2008
Wont do anything
See if the buzzing is coming from the timer, it may be broken. Try to change the timer to spin and see if the motor works.
Dec 02, 2013 | Maytag MTW5700TQ Top Load Washer
Buzzing sound wont spin out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
Washing Machines Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
