Question about GE Profile PSI23NCR Side by Side Refrigerator
Layer of frost on the bottom surface of ice maker
I have a year old GE side by side model GSH 22 JSTSS. Recently noticed a layer of frost on the under side of the ice maker. Also see minor frost on the sides and on packages. Is this normal? What should I do? Still seems to cool well enough
  • jisthereason Jun 23, 2008
    My icemaker and the dispenser both frost up causing my freezer door not to open at times, and also the ice will only come out crushed and not cubed.
  • 77 Answers
During periods of high humidity and or high use, it is not unusual to notice frost on surfaces in the freezer. the ICM is susceptible due to it being metal and having warm(compared to freezer temp) water in it. make sure the doors ar closed tight and nothing is stuck in the gasket area.
J
Posted on Jun 13, 2008
SOURCE:
ICE MAKER FROST UP AT CHUTE
is this a u-line? Or a GE? If its a U-line make sure the freezer door is closing and sealing. If its a GE then check the gasket and make sure that is sealing.
Jul 29, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
GE Side by side runs constantly.
EASY FIX!!! The drain is clogged up. All you have to do is take the back wall to the freezer off (lower section in freezer) And you will see another layer of frozen ice at the bottom (behind back wall). Get you a hair dryer and start melting. After a few minutes u will start to see a drain whole(size of a nickle in middle) concentrate you efforts on the drain hole. Now get some wire or something and stick down in hole, then pull out over and over till finally it drains all the build up water around the hole! GOODLUCK!!!
Dec 17, 2007 | GE GSH25JFR Side by Side Refrigerator
Ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSI23NCR Side by Side Refrigerator Logo
229 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Matt Sicignano
Level 1 Expert
